Cutting antifreeze with....
Old Sep 22, 2013 | 06:53 AM
wrongway1's Avatar
Default Cutting antifreeze with....
okay need a pretty quick answer as the Disco's in the back yard with the radiator & water pump out of it, and I picked up one gallon of 50/50 & a gallon of uncut Prestone antifreeze by mistake. I see that city water isn't good to cut it with, and distilled water is for flushing. What do you recommend I use to make this bottle 50/50??
Old Sep 22, 2013 | 07:13 AM
CUpgt's Avatar
Distilled water
Old Sep 22, 2013 | 07:45 AM
wrongway1's Avatar
Originally Posted by CUpgt
Distilled water
Thanks!! I appreciate your always coming to my rescue!! Nothing like a baptism under fire
Old Sep 22, 2013 | 07:51 AM
Be sure to reverse flush both rad and heater core. O rings for cooler lines on rad OK?
Old Sep 22, 2013 | 08:00 AM
antichrist's Avatar
FWIW I always buy full strength. It's cheaper
Old Sep 22, 2013 | 11:16 AM
And for the math word problem thinkers, pour in one gallon of the distilled water, one gallon of the 100% coolant, and top up with the 50/50 premix. Bleed, bleed, then bleed some more.
Old Sep 22, 2013 | 07:20 PM
wrongway1's Avatar
Got it done! New radiator, water pump, viscous, and replace the alternator again while I was in the area. Took 4 hours to get the darn water pump gasket surface clean (no idea what LR put it on with, but it was impervious to gasket remover!!). Had a bit of an issue with getting he heater to blow hot air )even after purging the air out of the cooling system twice), but after driving about a mile, it blew nice & toasty. Hope this is the end of the high temp issues because there's nothing left to replace!!
Old Sep 22, 2013 | 07:44 PM
Sam95disco's Avatar
Man I used tap water, we dont drive fast end sports cars lol
Old Sep 22, 2013 | 08:07 PM
CUpgt's Avatar
It doesn't have to do with being high end. It's the additives in tap water.
Old Sep 22, 2013 | 10:30 PM
jafir's Avatar
Or the naturally occurring minerals.
I wonder if I could use water from my dehumidifier. I know it's not considered safe to drink, because it might be growing bad things since it's never been boiled, but I would think it's free of minerals.
I think I'll just stick with the $0.88 distilled water from the store.
