D1 steering leak
Old Jul 18, 2012 | 05:43 PM
olywa's Avatar
Default D1 steering leak
My wife just called me and said the steering fluid leaked all out. Can I replace the seal or have to replace the entire box/pump? How bad is it?
Old Jul 18, 2012 | 06:14 PM
Bkreutz's Avatar
First find out what's leaking, a hose is more common than a box (and much cheaper to replace) highly unlikely (though not impossible) for the seal to leak badly enough to dump all the fluid that fast.
Old Jul 18, 2012 | 06:16 PM
olywa's Avatar
I'll check when I get home. The wife is pregnant with my twins so she won't be crawling under the rover.
Old Jul 18, 2012 | 06:43 PM
Bkreutz's Avatar
Start your check by looking under the hood, start at the reservoir and work your way down (visually) find the highest point of the leak and that's probably where the failure occurred. (The low pressure return line has a high failure rate too).
Old Jul 18, 2012 | 08:32 PM
Danny Lee 97 Disco's Avatar
When was the last time you checked the fluid level?
I would refill it after a god visual and a cleanup and then start it and watch to see what happens.
You are aware that it uses transmission fluid and not power steering fluid aren't you?
Old Jul 18, 2012 | 10:13 PM
olywa's Avatar
The wife put power steering fluid before I could tell her it was tranny fluid. How bad is that.
Old Jul 18, 2012 | 10:33 PM
thehun's Avatar
Its probably ruined after she did that
Old Jul 18, 2012 | 10:39 PM
olywa's Avatar
Are you serious?
Old Jul 18, 2012 | 10:42 PM
Bkreutz's Avatar
Originally Posted by olywa
Are you serious?
Either one will work fine.
Old Jul 18, 2012 | 10:44 PM
thehun's Avatar
You can not put Power Steering fluid into a D1 Power Steering system..it must be ATF
