D1 Weird Sounds - Power Steering Pump?
Old Feb 17, 2023 | 12:19 PM
Gregory Villarosa's Avatar
4wd High
Default D1 Weird Sounds - Power Steering Pump?
Name this sound! Tensioner, belt, air in line, pump? Apparently I'm having issues with the power steering. Fluid was a bit low. I havent driven truck in 6 months so issue just came up without warning when I took it in for a warrant of fitness. Any advice appreciated!
Old Feb 17, 2023 | 03:02 PM
sandmanspeaking's Avatar
my guess would be a new serpentine belt. Then try again.
Old Feb 17, 2023 | 03:17 PM
WaltNYC's Avatar
somewhat related....could be a bearing in one (or all) of the pulleys.
run it for a minute without the belt.
Old Feb 17, 2023 | 03:47 PM
hrhoward's Avatar
Take the belt off, run for a bit.
While belt is off, spin accessories and tensioner pully by hand.
Noise still hiding? Put belt back on, squirt wee bit of wd-40 or the like on spinny things bearings without getting any on belt.
Old Feb 17, 2023 | 11:47 PM
4wd High
Default Just Fluid Top-Up?
Would it make sense that the noise could come from low power steering fluid? I topped it up, ran it and the noise was still going strong, then topped it up again and now it seems to have disappeared. Should I expect the sound to return?
Old Feb 18, 2023 | 09:31 AM
Yeah, that could be it. But I hear noise from contact (two things hitting each other) on a fan belt in that audio. Can you send new audio with it topped off?
Old Feb 18, 2023 | 11:50 AM
Harvlr's Avatar
If it was low fluid, the sound is likely due to air bubbles in the fluid. Topping it up may cure it, but low fluid might indicate a leak and you may have low fluid again soon.
Old Feb 18, 2023 | 05:06 PM
4wd High
True. Cheers for that. And attached is the new recording of engine post top-up.
File Type: mp3
rangerover2008
May 12, 2015 11:50 AM
Hercu
Mar 9, 2015 07:48 AM
kenk
Oct 7, 2013 07:45 AM
pkunze
Feb 11, 2013 06:49 PM
SICSOLX
Nov 5, 2007 10:33 PM
