D90 Front Brakes
Old Jun 28, 2012 | 11:35 AM
Jake1996D1's Avatar
Default D90 Front Brakes
So you guys complaining about the stopping power of your disco here's your solution. I picked up this kit thru Lucky 8 for less than $400.
D90 front calipers which if you cant tell from the pic - These things are HUGE a lot bigger than the disco calipers. and the pads are quiet a big bigger as well.
I didnt pick out the rotors (the cross drilled vented part) but they are obviously vent.
I needed these because my current brakes cant stop the 35's and my rotors are glazed from being overheated from slowing down coming off mountain hills.
All of the parts bolt right up - the only other thing I need is a hadware kit with pins ect- However you do have to bend one hard line so having a set of brake tube bending pliers is a good idea.
I will let you know how they work once I have a chance to get them on.
Old Jun 28, 2012 | 12:53 PM
wheelgarage's Avatar
On my Disco bucket list....fo'sho!!!
I was going to do it part by part, but if Lucky8 has a kit...why not.
Old Jun 28, 2012 | 12:58 PM
Jake1996D1's Avatar
Yea I think these rotors are terrafirma (guessing based on galvy).
It doesnt make sense to do it piece by piece cause you need all these pieces to make it work
Brakes are one of those things everybody should spend their money on and make sure they can stop their 5000lb **** boxes
Old Jun 28, 2012 | 02:17 PM
ValveCoverGasket's Avatar
definitely looking forward to some pics!
Old Jun 28, 2012 | 02:21 PM
Discolife's Avatar
I have them and slotted drilled on rears too. They work great.
Old Jun 29, 2012 | 07:36 AM
antichrist's Avatar
I can tell you right now they work great, though I also did SS flex lines, new rears and new MC at the same time, so not exactly the same. I went with rebuilt calipers, but not had any issues.
https://landroverforums.com/forum/ge...acement-39705/
Old Jul 2, 2012 | 08:42 PM
Jake1996D1's Avatar
Getting them on - Have to pull the dust guards because they are rubbing - probably because they are deformed. Also need to route the hard line a little better.
Old Jul 2, 2012 | 10:10 PM
fishEH's Avatar
Bout time you lost those mud shields!!!!! Haven't had a rock stuck and squealing since I pulled mine.
Old Jul 3, 2012 | 05:50 AM
antichrist's Avatar
These work great for tight radius bends in confined places.
Eastwood Brake Line Forming Tool Pliers
Old Jul 3, 2012 | 09:24 AM
Jake1996D1's Avatar
Yup I already have some
Just ran out of time on it
