Dash Temperature Gauge Fluctuation w/ Heater On
Old Nov 27, 2014 | 12:55 PM
TDRover's Avatar
Bought an ultra gauge and will look to attack the grounds next weekend.
Mark G- I haven't had to add coolant at all and don't have any other symptoms of HG problems, but I'll take another look for sure.
Old Nov 28, 2014 | 12:59 PM
TOM R's Avatar
I your not losing coolant and water sound in dash there is air in system, from what ? Who knows , you don't have to yave bad headgaskets to lose coolant, bad hose loose hose clamp, leaking water pump etc.
either way get the right front jacked up remove cap and plug on rad and run to bleed the air out
Old Dec 20, 2014 | 09:53 AM
TDRover's Avatar
Just wanted to report back.
Fixed the heat and related dash temp spike- found a loose ground. So thanks everyone on that.
Bled the system multiple times and it appears to be fixed but i can still hear it ever so slightly. Also found out that my t-stat was sticking so replaced that as well.
She runs like a top now so thanks again.
nflpa29
Feb 28, 2023 07:04 PM
dcarr1971
Sep 19, 2012 09:08 AM
Optimistic.1
Mar 29, 2011 05:46 AM
somekid
Jan 5, 2007 07:50 PM
