DD disco with 33's and no lift
Old Nov 11, 2012 | 11:51 AM
  #31
fishEH's Avatar
Originally Posted by Jake1996D1
He cut that seem off and what looks like an inch or so around the wheel well.. What does bump stops have to do with anything? I'm sure he has like 3" of up travel before his springs are fully compressed..
I think we're talking about different seams, it seems.
Well bump stops are there to limit uptravel you see. His tires are 4" taller than stock, so 2" taller in the wheel well. Long and short of it is he's trying to shove 10lbs of sausage in a 5lb casing.
Old Nov 11, 2012 | 12:58 PM
  #32
Jake1996D1's Avatar
I fit my 10 lbs of sausage in all the time.. Just takes a little force
Old Nov 11, 2012 | 01:18 PM
  #33
fishEH's Avatar
How does Zuki feel about your 10lbs of sausage in his 5lb casing?
Old Nov 11, 2012 | 01:52 PM
  #34
Jake1996D1's Avatar
You would try to make this gay.. you sick ****
Old Nov 11, 2012 | 03:07 PM
  #35
fishEH's Avatar
900 posts and you still don't know four letter words get censored. That's how I know you're gay.
Old Nov 11, 2012 | 03:15 PM
  #36
Jake1996D1's Avatar
I don't care to keep track you get the point queer
Old Nov 11, 2012 | 10:12 PM
  #37
fishEH's Avatar
I rest my case.
From Pirate:
Originally Posted by zukijames
Body Lift would make my tires stop rubbing and then I could disconnect my sway bars..and it wouldn't raise the cog as much as a suspension lift
But idk I know I should just leave it how it is
Old Nov 12, 2012 | 09:19 AM
  #38
zukijames's Avatar
Moab has been a blast how many of you have done Prichett canyon ? I made it winched 3 times but climbed rocker knocker un assisted
So You are alright totally pointless rig and horrible
Off road
Did steel bender twice , flat iron Mesa , and Prichett canyon,greenday at bfe and the fun part of strike ravine
Been with a jeep buggy on 42s, a ls1 powered jeep on 38s, Toyota truggy on 37s .
And they all have been impressed.
Yesterday I let my gf drive all day today will probably be the same
Top of Prichett canyon look up rocket knocker on YouTube because I'm sure your big
Lifted rigs are to cool to do that
Trail.
Tires do rub on radius arms.. So what. This rig is so stable I'd rather make a few 3 point turns then tip over
I'll get more pics soon off how bad it sucks..
Ps I welded the rear spider gears to the carrier
Then I drove 210 miles with only 1 rear axle shaft.
I'm sure that will upset you guys .
Old Nov 12, 2012 | 09:36 AM
  #39
zukijames's Avatar
Do any of you guys know what roll center ?anti squat? Static center are?
I you did you'd under stand big lifts keepjng the same suspension links are lame.
Ps so my tires measure 32 tall. Do stock tires rub annul stuff or do they have a little
Room?
So make the top of the tire 2 inches taller .. Now trim 1.5 inch of fender.
And realize that gets rid of that 1 inch lip inside the fender.
Now realize most of you are retarded and I've wheeled more in theonth I've had the rig than of you have all year thanks Jake.
I think most of these guys have only a few ounces of sausage so they compensate by being rude on the Internet and big
Lifts.
As ruining my expensive tires. They were either 400 or 500 brand new.. Putting me 1500$ dollars into a rig with 33s and a locked rear end
Hope you guys had a fun weekend tellin me it won't I know I had a great weekend proving it works .
Thanks guys
Old Nov 12, 2012 | 09:51 AM
  #40
madcrawler girl's Avatar
I would like to see you guys make it through pritchett, steel bender, flat iron mesa, and green day with out bigger tires and your lift kits promise ya it won't happen. I
I have a landrover with 40's and only a two inch lift. His 33 inch tires and no lift is great! Making something taller at the body doesn't make it more stable makes ya tip over do your home work guys try something before ya talk.
