De-computerize
Old Jul 30, 2017 | 12:58 PM
knbaudio's Avatar
Default More work
Ok today took computer out and apart looks like brand new one no rust or anything. I put the used computer in and it idles little lower but will not run right spits and sputter. It acts like a died spot in throttle. I found the charcoal filter vacuum hoses old and hard one was loose so i replaced them. I pit original computer idle lower but 1200-1500 but no other change.
Old Jul 30, 2017 | 01:25 PM
Mark G's Avatar
Ok, that's good to know. Did you drive it a little? Sometimes a computer needs to re-learn in order to settle to a good idle. Not just around the block either. What's the engine vacuum look like? You could have an intake manifold leak, or brake booster leak. Can you see with your diagnostic tool what the vacuum is, or do you have a gauge to put on it? Is it steady? How many PSI at idle ..and at off-idle RPM?
WHat signals are you gettin from the O2 sensor? MAF sensor? If you unplug the IAC, what happens to the idle?
Old Aug 1, 2017 | 02:34 PM
Mark G's Avatar
Just curious how you came out on items you've checked recently? You should be narrowing things down pretty well soon.
Old Aug 2, 2017 | 05:35 AM
knbaudio's Avatar
I only have weekends to do any work on it.I drive truck with daily home time but with rain and usually dark when I leave and dark when I get home. With very little time to do family things. I just deal with the rover or just ride motorcycle until weekends. But will let you know what else I find.
Old Aug 3, 2017 | 12:48 PM
Mark G's Avatar
Takes 'guts' having a Disco as a primary vehicle.
Old Aug 19, 2017 | 04:32 PM
knbaudio's Avatar
Default Update
Sorry guy for the long time on update. I got sick over vacation still fighting off lung and cough.
ok no change If I unplug IAC when running. Still waiting for friends fuel psi tester. It has been running worse on some days back firing and failing on its face. Some morning it doesnt fire right take col time or I have to give throttle. Did vacuum check requick after working o daughter jeep.
vacuum -18psi 1500 rpm idle
obd2 reading cold not running
dtc 0, fuel 1 ol, fuel 2 ol, load pct 0.0, ECT 26- 27 degree c, shrtf1 0.0,long ft1 -24.2, shrift 0.0, longft2 -24.2, rpm 0, vas 0, sparkadv 20, iat 34 degree, MAF 0.00, tps 11.4, airstat off, o2sbb1s1 1.020, shrtftb1s1 0.0, o2b1s2 1.020, shrtfb2s1 0.0, o2b2s2 1.015,
cold running same order from above
0, cl, cl, 18.4, 41, 24.2, -24.2, 3.9-8.6, -24.2, 1828-2000, 0, 44, 36, 0.13, 11.8, off, 0.995-1.000, 24.2, 1.005, 0.030- 0.995, 7.5-11.7, 1.005
Old Aug 20, 2017 | 11:52 AM
robertf's Avatar
-18psi? You might want to recheck that, assuming you are on Earth.
Inspect the wiring for the crankshaft position sensor. It corrodes and causes it to run like that.
Old Aug 20, 2017 | 07:24 PM
knbaudio's Avatar
Hey Robert yes I'm on earth intake vacuum and yes gauge is right 0 to - number for vacuum psi. And intake vacuum would be - number it doesn't build Positive psi. And yes new wire for crank sensor and new sensor less than a year old.
Old Aug 21, 2017 | 09:44 AM
robertf's Avatar
Is it an auto? If the crank positioning wiring is good you may want to pull the flex plate inspection cover and see if any of the pickup teeth are damaged.
your gauge probably reads in*mg for negative #s. -18inmg is about -9psi. -18psi is impossible
Old Sep 2, 2017 | 12:17 PM
knbaudio's Avatar
Default Update
Well got my hands on a snap-on computer it can read but not change anything. I still reading -38 temp in Florida. No check engine but stored codes on both computer ( p0158, p1179,p1177,p0451,p1317) on top of watching live it says road speed is anywhere from 1300 mph- 20k mph. Tried unplugging seed sensor didn't change anything. So now what I don't have use of computer for long just this weekend.
