Death wobble?
Old 01-19-2014, 09:08 PM
ihscouts's Avatar
Correct preload method is with a torque wrench (Rave) and not the fish scale that could be used with the 94/95's. Calebbo is lucky there..... Highly suggest buying grease-able HD TRE's. The heims would be for max articulation. If it's a dd I'd stick with plain. X2 on the damper.
Old 01-19-2014, 09:57 PM
kingsly's Avatar
Just checked the TRE's and panhard rod. Tre's are definitely mobile, but tighter than I expected. Panhard is fine. Oh and yep the front brake circuit is nearly empty.
Old 01-19-2014, 11:07 PM
calebbo's Avatar
Yeah I used the fishscale method. I set mine to 13lb for some extra resistance. Specs is around 10.
Old 01-20-2014, 07:40 AM
antichrist's Avatar
Fish scale is for non-ABS, torque wrench is for ABS. '95's have ABS.
Old 01-20-2014, 07:41 AM
ihscouts's Avatar
+3lbs should wear in just fine, probably only add a pound when everything settles in.
Old 01-20-2014, 07:45 AM
ihscouts's Avatar
Duly noted. So there isn't an NAS built without ABS. When did they incorporate ABS into the RRC's?
Old 01-20-2014, 12:04 PM
jafir's Avatar
Not good answer, but my buddy's 1990 had it. It was a county though, so maybe the nicer trims had it by then.
Old 01-20-2014, 05:42 PM
antichrist's Avatar
Yeah, I think it was 1990.
Old 01-20-2014, 08:27 PM
ihscouts's Avatar
So Calebbo.....now that you've finally "finished" your actually not "FINISHED". I know it would be a major pain in the butt to do it again but........I wonder how far off between the two methods......
Old 01-20-2014, 10:41 PM
calebbo's Avatar
Meh, I disabled my ABS so it's kind of whatever if the Defender guys can do it I guess I can too. I don't think it's too big of a difference, yeah? I mean I guess I could go back and torque it and tell you guys the fishscale weight so we could just fishscale it from now on?
Quick Reply: Death wobble?
