Decibel Measures
Old Oct 25, 2011 | 08:25 PM
SenatorPerry's Avatar
Default Decibel Measures
Just wondered,
I replaced the rubber weather stripping on my 1997 Discovery LSE. This included all of the doors. On the back door I added more weather stripping across the top of the door frame to tighten everything up.
Driving at 55 on flat ground at speed my decibel measure is at 61-63 one foot above the transmission shifter in the center. On a hill it increases to around 71. How does this measure up to you all?
Thanks for any feedback.
Old Oct 25, 2011 | 08:33 PM
turf63's Avatar
what are you using to measure decibels? I dont readily keep equipment like that in the truck. My truck sounds like a single prop airplane because of my tires. I think it shook a filling out of one of my cavities once, so im assuming if more decibels is better, then i might have the high score.
Old Oct 25, 2011 | 08:43 PM
I'll bring one home from my office and experiment, may take a couple of days to get results back to you.
Meanwhile, if sound level increases 10 dB going up hill, when is last time you greased drive shafts (front and rear), drained and refilled diffs and transfer case, what oil weight and type are you running in them, and when was tranmision fluid /filter changed? Exhaust leak? Just thinking about what could make that much of an increase...
I went to 85W140 synthetic in my transfer case and I think it is quieter, but that is based on the old Mark 1 Ear Drum, which has been abused in my distant youth by Iron Butterfly and such and obnoxious volume levels... point being that hearing damage is forever.
Old Oct 25, 2011 | 08:51 PM
deciBel and Decibel applications on my Droid X along with a CEM decibel meter. They are within a few decibels of each other when measuring. My goal was to get the noise and rattles down, but need to identify a floor base level.
Old Oct 25, 2011 | 08:54 PM
...that is based on the old Mark 1 Ear Drum, which has been abused in my distant youth by Iron Butterfly and such and obnoxious volume levels... point being that hearing damage is forever.
In-A-Gadda-WHAT??!!!????? I cant hear you over the awesome 15 min drum solo!!!
Old Oct 25, 2011 | 08:55 PM
I will use my iPhone on my way in/home from work tomorrow and report back.
Old Oct 25, 2011 | 08:59 PM
Quiet and Rover may be mutually exclusive terms....
I am sure the exhaust has a leak. The rear shaft was replaced last week. The front was done several months back. 10W40 Mobile a few thousand miles back. In a few weeks I plan on replacing the exhaust and changing the tires.
Old Oct 25, 2011 | 09:06 PM
re: I cant hear you over the awesome 15 min drum solo!!!
One of the radio statio disc jockey favorites, allowed a quick break for whatever reason. Also the gold standard for torture testing sub woofers...
Old Oct 25, 2011 | 09:07 PM
Service diffs and transfer case might help on the noise.
