Defender 110 2010 parts that match disco I 1998
Old Apr 17, 2012 | 11:12 PM
Miguel Angel de la Cueva's Avatar
Default Defender 110 2010 parts that match disco I 1998
Hello everyone, need your advice!! is there any parts from a Defender 110 2010 that can fit a Disco 1 1998 4.0?, i heard shocks and springs can fit along with other suspention parts!!
Old Apr 18, 2012 | 08:57 PM
As I do not know how much they changed from the earlier models, but almost everything from the early models will fit, axles, springs, shocks, rims...
Old Apr 18, 2012 | 09:00 PM
Jake1996D1's Avatar
Yes springs and shocks will convert over but they may not be the right spring rate for a big ole 110.
Where are you getting a 2010 Defender in the states?
Old Apr 19, 2012 | 01:49 PM
Thanks, the Defender is located in Mexico, not the US, Land Rover dealer in Mexico is selling/importing New 90 and 110 Defenders from 45.00 dlls and up since 2010 it, this one was involved in a bad accident and the exterior is very damaged but the rest is in good shape, i want to buy some parts for my DI when stripped if they fit of course.
Old Apr 19, 2012 | 03:17 PM
ptschram's Avatar
LOL-you guys must not see many 110s.
The rear springs are likely much larger in diameter. It likely has a Salisbury rear axle that while the entire axle is interchangeable, none of the guts are. I know that the spring perches from my Salisburys were much larger in diameter than the original springs on my SWB.The front axle is more like the P38/DII axle than a DI.
Old Apr 19, 2012 | 04:32 PM
Jake1996D1's Avatar
Right this is why OME sells different #'s for rears, I should have known better. 110's have different front axles that 90's/D1/RRCs? I know that non NAS parts are not direct swaps as they have the "1 ton" front axle set up guys used to run on D1's and RRC's for the heavier duty CV's...
I havent seen a 110 newer than an 1985 hahah
Old Apr 19, 2012 | 08:10 PM
Yeah because we are in the US and there are zero 2010 Defenders hear let alone any 110's so we should have known straight away that the 2010 Defender 110 had different sized springs, I mean it is after all common knowledge right?
Old Apr 19, 2012 | 08:35 PM
Jake1996D1's Avatar
I'm willing to bet PT hasnt seen a 2010 110
How many 110's have you seen in person Spike?
Old Apr 19, 2012 | 09:11 PM
110's, three or five, two to three 109's, a dozen 90's, tried to buy a 88", admired a couple more 88's.
czopper
Feb 21, 2014 10:36 AM
corprin
Jan 28, 2013 12:16 PM
Savannah Buzz
Jul 30, 2012 04:55 AM
piyush123
Defender
Jul 20, 2010 02:45 PM
