Did I just get screwed?
Old Sep 1, 2010 | 04:12 PM
dev99disco's Avatar
Default Did I just get screwed?
Fuel pump died. Took it to shop and to change the internal fuel pump not the assembly cost was $235 labor. Did I just get screwed?
Old Sep 1, 2010 | 04:30 PM
Bajapower's Avatar
Could you have performed this fix yourself?
Old Sep 1, 2010 | 05:14 PM
discomedic4's Avatar
Would have been much cheaper to do it yourself obviously and it maybe a bit high but I have heard of worse. Next time something breaks check here first. You could save yourself a ton of money. There is a write up in the how to section that would have walked you through changing out the fuel pump.
Old Sep 2, 2010 | 09:52 AM
hilltoppersx's Avatar
fuel pump is $100. depends on how much your time is worth to you?
Old Sep 2, 2010 | 12:56 PM
ColoDisco's Avatar
I agree. Sounds like a hour or two for labor, that sounds normal for a shop to charge. Depends on what your time is worth.
Old Sep 2, 2010 | 02:19 PM
okdiscoguy's Avatar
Not bad. I just did mine for $75 at home.
Old Sep 2, 2010 | 02:59 PM
NiteTrain's Avatar
I have to say yes, that is too much in labor..the D1 fuel pump appears to be the easiest fuel pump in the world to change but I have not changed one yet.
Old Sep 2, 2010 | 03:59 PM
Danny Lee 97 Disco's Avatar
Sounds high to me. All you have to do is remove the rear carpet and pad, then remove the screws holding the inspection plate in place. You unscrew the red plastic ring using a hammer and flat bladed screwdriver. Lift pump assembly out of gas tank.
I put a new fuel pump assembly in mine, right at 100 bucks from RN for the pre-AEL version, a 98 is more due to AEL. Mine had a cracked top piece where the metal fuel lines feed into the top plate.
That is one of the simplest repairs on a Discovery.
dev99disco
Sep 1, 2010 09:06 PM
jarkalina
Oct 31, 2009 08:15 PM
Speed racer
Nov 1, 2008 12:38 AM
Speed racer
Oct 30, 2008 11:29 PM
Erik
Jun 17, 2007 11:59 AM
