Sponsored by: CARiD
Remove & Replaced batteryNow I'm screwed HELP !!!!
Old Oct 30, 2008 | 10:17 PM
Speed racer's Avatar
Default Remove & Replaced batteryNow I'm screwed HELP !!!!
Hey guys,I have a 2005 Range Rover HSE and I disconnected the Negativebattery cable and then hooked it back up.. Now whenI get in the car and start it, the message board says-Air Suspension is Inactive Also the BRAKE ABS light is now lit up-Also The Traction Control Light is now lit up too..NO CODES THOUGH.
The car was running perfect, since the dayI got it andI have had no problems at alland Nowarning lights haveever came on..What the Hell happened? How can I fix this problem.. Is there a reset button or something???
Please help guys, I'm screwed Again... I need to just leave stuff alone..... I'm not even sure ifI can drive the car with the Air Suspension Inactive..
Old Oct 30, 2008 | 10:28 PM
WolfPack's Avatar
Default RE: Remove & Replaced batteryNow I'm screwed HELP !!!!
Im pretty sure those 3 lights are like the Disco's 3 amigos. Probably just needs to be reset. Give your dealer a call?
Old Oct 30, 2008 | 11:29 PM
The Problem has been fixed... One of our great members told me to turn the steering wheel all the way to the left and then all the way to the right and the codes all vanished.... You guys are the best ! Thanks for everything
wheelgarage
Oct 1, 2011 03:12 PM
caleb
Jan 6, 2010 11:26 AM
jarkalina
Oct 31, 2009 08:15 PM
Speed racer
Nov 1, 2008 12:38 AM
Erik
Jun 17, 2007 11:59 AM
