Diff lock light on, horrible grinding noise
Old Mar 5, 2012 | 02:53 PM
callmehero's Avatar
If I can get it moving long enough to get home I'll take the console apart and do the whole thing properly.
Silly truck, why did you just pretend you were working?
Old Mar 5, 2012 | 03:05 PM
slanginsanjuan's Avatar
with that kind of (good) attitude you'll go far with that rig! good luck.
Old Mar 5, 2012 | 07:18 PM
dansgt's Avatar
try disconnecting the linkage and manually rotating it with a wrench from below. that'll also tell you where the problem is if that works.
Old Mar 5, 2012 | 08:45 PM
Danny Lee 97 Disco's Avatar
There is another thread on here that was just recently doe by Pinkytoe about his CDL. Look at it. There is a picture of the part you need to manually rotate to lock the center diff.
Old Mar 6, 2012 | 11:40 AM
WaltNYC's Avatar
This may help. It is a view of the transfer case from the perspective of the driver's side (U.S.). This one happens to be changed via air locker but the twisting action of the top 'nut' is the same. You can see the output flange to the front drive shaft with the four bolts on it.
http://youtu.be/LuSnycTKBpM
Old Mar 6, 2012 | 11:47 AM
WaltNYC's Avatar
and another with the wrench
LT230 Difflock Mechanism - YouTube
Old Mar 6, 2012 | 11:54 AM
WaltNYC's Avatar
a view from the passenger side..
Air Locker CDL - YouTube
Old Mar 6, 2012 | 02:12 PM
Webshots Rides offers thousands of the best car wallpapers.
DannyLee97Disco > albums > Diff Lock Still Stuck
USING WRENCH OR SOCKET, ROTATE CENTER NUT CCW TO LOCK OR
CW TO UNLOCK THE CENTER DIFF
Old Mar 6, 2012 | 03:34 PM
callmehero's Avatar
I think the sound must be the front axle tearing itself to pieces. I pulled the link on the diff lock and manually set it to lock and babied it home. Looks like I've got a bigger problem than just the differential.
Thanks everyone!
iddis
Jul 6, 2015 07:23 AM
cornbreadj
Dec 27, 2014 07:50 PM
DiscoMississippi
Oct 15, 2008 01:05 AM
khandrh
Aug 8, 2007 08:17 AM
trangle23
Nov 20, 2006 12:39 PM
