Diff lock worn engage
Old Aug 26, 2014 | 11:16 AM
Rov3r's Avatar
Default Diff lock worn engage
Will not engage. So I went to engage my diff lock, doesn't move. I can go up to neutral and low gear, but will not move left into lock. Anyone have any ideas on how to get it over? I sprayed some lube on the linkage, and still no good.
Old Aug 26, 2014 | 11:30 AM
EricTyrrell's Avatar
Apply gentle pressure to the left while the truck is rolling slowly forward or back. This lets it engage when parts line up in the diff and bind is released.
Old Aug 26, 2014 | 11:34 AM
Rov3r's Avatar
And if that doesn't work?
Old Aug 26, 2014 | 11:57 AM
Dig into the linkage.
Old Aug 26, 2014 | 12:39 PM
Rov3r's Avatar
Are there any how to videos or write ups on how to do this?
Old Aug 26, 2014 | 01:03 PM
Yes the RAVE has instructions
You basically remove the center console, then remove the transfer case shifter boot, and you have access to everything. There's a lot of parts to remove along the way, but you'll be fine. When you get to the shifter boot you need to drill some rivets out. Don't let this scare you. Just get some more pop-rivets to reassemble.
Old Aug 26, 2014 | 01:05 PM
Another option is to feel around from under the truck and try to grip the linkage. Not sure you'll be able to do much though. Might be worth a try.
You could also jack up one wheel, get someone to turn it by hand back and forth, while trying to engage diff lock.
Old Aug 26, 2014 | 01:38 PM
Rov3r's Avatar
I got it. Took some pb blaster, lube and a hammer.
cornbreadj
Dec 27, 2014 07:50 PM
TRIARII
Feb 27, 2014 08:38 AM
Savannah Buzz
Off Topic
Sep 13, 2013 01:21 AM
jdogg
Jan 28, 2013 10:00 PM
instg8r
Jan 7, 2012 03:13 PM
