A Different Kind of CDL Stuck Problem
Old Sep 19, 2012 | 10:35 AM
E36 Phantom's Avatar
Default A Different Kind of CDL Stuck Problem
Hey everyone! I've seen lots of thread where the lever was stuck, but this is not the case for me.
My lever moves freely between all positions, always engages hi/low readily, always engages CDL easily in low or high, and moves smoothly back to open....except that it doesn't actually disengage. The light stays on and it remains locked.
It takes a combination of rain dances, voodoo magic, and extensive sacrifices to the Land Rover gods (and a touch of luck) to finally get it disengaged.
What component would let the lever move freely while not actually disengaging lock? This is a 95 DI. Thanks!
Old Sep 19, 2012 | 10:58 AM
WaltNYC's Avatar
I'd guess the little plunger switch inside the transfer case is 'sticky'. If the lever moves (and the linkage is not broken) the CDL is un-locking. The light in the dash is triggered by that plunger switch. Here is a picture of it courtesy of the AB website...
Differential Lock Switch On Transfer Case (PRC2911 Same Fit As Part # PRC2911-LUCAS) - Land Rover switches/control unit/actuators from Atlantic British
Old Sep 19, 2012 | 11:06 AM
That switch is just for the light, right? The light is fine, its on when engaged and immediately goes out when disengaged.
The problem is the lever moves to right place but the diff physically remains locked. I think there's a component along the linkage somewhere that has too much play and doesn't force it to disengage, was hoping someone knows what and where that might be.
Old Sep 19, 2012 | 11:16 AM
WaltNYC's Avatar
If the lever is moving but the CDL actually remains locked (not simply a light on the dash), yes, your linkage is buggered. I misunderstood your explanation. I'm surprised it locks in the first place given this description. There are tons of CDL linkage threads on this forum and videos on Youtube that will be immeasurably more beneficial to you than anything I might be able to write.
Old Sep 19, 2012 | 11:19 AM
Might want to check the connection at the CDL nipple and make sure it is adjusted and moving to both limits.
Old Sep 19, 2012 | 11:45 AM
CUpgt's Avatar
Check the plastic bushing on the actual shaft as well
Old Sep 19, 2012 | 12:32 PM
MrFister's Avatar
you'll probably want to be in the garage when you check the nipples. don't want to get caught diddling your rover in public
Old Sep 19, 2012 | 08:17 PM
Mine does the same thing sometimes but driving in reverse for a few feet always unlocks it.
turbodave
Mar 29, 2019 07:22 AM
ImQuattro
May 1, 2014 08:36 PM
Street Wolf
Off Topic
Jan 17, 2012 07:55 PM
lipadj46
Jun 21, 2009 09:17 PM
