Differential Housing Case
#21
Yeah so I parked her in front of the house. When I let go of the gas it makes this rubbing sound, when I press the brakes it goes away. Parked her, calling different shops now to see who can give me a diagnostic.
EDIT:
Went to a mechanic and he took a drive with me. Showed him how it only made the noise when I was coasting and stopped when I was braking. It also helped me brake sometimes like I had extra braking power. Next he put it on a lift, checked out the tie rods and noticed first off my bearings were loose and that my FRONT, rear tie rod was loose and the bushings was bad. Told me he was very sure that was the reason and didn't charge me for diagnostics. He even went to the store with me to get the right parts. So I spent $60 on 4 wheel bearings (I know I could have just repacked the old ones but at least I don't have to worry), tie rod, and a mini-bucket of wheel bearing grease. Going to try to do the bearings at least tomorrow.
EDIT:
#22
again...wow
unless we are dealing with the "magic bullet theory" here I just don't see how solving a probable wheel bearing issue, worn tie rod ends and bushings explains away how something blew a HOLE in the Diff housing from the inside as you stated.
Based on the mileage and other problems you have described in the past doing the bearings and TRE's is honestly the best thing I have heard you do to service your rig thus far.
patching /welding over a HOLE in a pumpkin without determining the internal cause by closely inspecting the diff gears, bearings and pins was nutty my young friend.
I find myself wishing you bought a Jeep as your first project car...
#23
Here is what your differential looks like out of the truck.
http://www.roverlandparts.com/1994-1...bly-front.aspx
It is pretty easy to remove and you can only do a through inspection by removing it.
If you drain the fluid and no chunks fall out you might be ok...for now.
But you definitely shortened the life of the diff by running it dry.
You knew it was leaking, you should have at the very least checked the fluid level and filled it everytime you wanted to drive it.
These trucks are very durable and more forgiving than they ever needed to be.
#24
#25
If you are lucky all you do is strip the spider gear and the front axle just free wheels, if you are not lucky then it could take out more than what the truck is worth.
CV joints, axle shafts, drive shaft not to mention because it is on the steer axle if the wheels lock up while you are on the expressway and its raining or snowing you could skid out of control and crash or worse yet take out a innocent by stander.
Then you could have a law suit on your hands because you already knew there was a problem so you are totally at fault and liable for everything upto and including involuntary manslaughter.
#26
#28
#29
#30
I like Claire just the way she is, running but always needing something. Keeps me busy, out of trouble, and interested! I gotta say I haven't had to do so much repair work than on her. Everything else has been performance but THIS IS SO MUCH FUN TO ME!
That all depends on how fast you're going, if your turning, etc.
Then you could have a law suit on your hands because you already knew there was a problem so you are totally at fault and liable for everything up to and including involuntary manslaughter.
