Diognostic Port?/ Alternator?
I am looking for the diognostic port my 97 disco please tell me where it is.
And on another note can anyone lead me in the right direction on how to tell if i have an high uotput altenator with truck running at the batt there is 18 volts and some change seems high but was hoping it was high output the rig has 4 aux light switchs and i can tell there was a light bar mounted to the rain gutter. And the wires were sticking out the roof where they were hacked off so maybe im gonna luck out.
If your meter is accurate, your alternator is bad. Output voltage is supposed to be regulated, and anything over about 14.4 volts is suspect. One thing that can make volts go high is a bad strap between frame and engine block, that is usually near the starter. For test purposs use a battery jumper cable between (-) negative battery terminal and something bare metal and thick on the block. You can also get a free alternator / battery test at most auto parts stores.
I paid my "tuition" on the loose ground strap - Motorola two way radio quit, put in another, it quit, put in a third, it quit. Was getting 18 volts to them, loose bolt on frame jumper of a Chevy pickup; radios were about $1000 a piece, back when I made $135 a week. I worked for a very good understanding boss, who later made sure the company paid for my college tuition. Yes, sir, high volts is bad business, smokes amps, radar detectors, fancy stereos, GPS, etc.
You may have to poke around in the driver's footwell to find the plug or drop the access panel that is under the steering wheel. I rerouted mine and wrapped the bundle with friction tape and have it permanently exposed in the footwell for easy access. The PO had pushed it underneath and it was difficult to get to.
