Diognostic Port?/ Alternator?
Old Oct 18, 2011 | 07:02 PM
Fitzy250's Avatar
Default Diognostic Port?/ Alternator?
I am looking for the diognostic port my 97 disco please tell me where it is.
And on another note can anyone lead me in the right direction on how to tell if i have an high uotput altenator with truck running at the batt there is 18 volts and some change seems high but was hoping it was high output the rig has 4 aux light switchs and i can tell there was a light bar mounted to the rain gutter. And the wires were sticking out the roof where they were hacked off so maybe im gonna luck out.
Old Oct 18, 2011 | 07:05 PM
fishEH's Avatar
Your OBDII plug is in the drivers side footwell, towards the transmission tunnel IIRC. At least that's where mine hangs since I removed the trim in that area.
Not sure on your alternator.
Old Oct 18, 2011 | 07:16 PM
If your meter is accurate, your alternator is bad. Output voltage is supposed to be regulated, and anything over about 14.4 volts is suspect. One thing that can make volts go high is a bad strap between frame and engine block, that is usually near the starter. For test purposs use a battery jumper cable between (-) negative battery terminal and something bare metal and thick on the block. You can also get a free alternator / battery test at most auto parts stores.
Old Oct 18, 2011 | 07:22 PM
The alternator range is 13.6 to 14.4 volts, anything outside that and you are in trouble.
Old Oct 18, 2011 | 07:23 PM
Fitzy250's Avatar
Ill take a look and see whats going on
Old Oct 18, 2011 | 08:18 PM
I paid my "tuition" on the loose ground strap - Motorola two way radio quit, put in another, it quit, put in a third, it quit. Was getting 18 volts to them, loose bolt on frame jumper of a Chevy pickup; radios were about $1000 a piece, back when I made $135 a week. I worked for a very good understanding boss, who later made sure the company paid for my college tuition. Yes, sir, high volts is bad business, smokes amps, radar detectors, fancy stereos, GPS, etc.
Old Oct 18, 2011 | 08:34 PM
Danny Lee 97 Disco's Avatar
You may have to poke around in the driver's footwell to find the plug or drop the access panel that is under the steering wheel. I rerouted mine and wrapped the bundle with friction tape and have it permanently exposed in the footwell for easy access. The PO had pushed it underneath and it was difficult to get to.
Old Oct 18, 2011 | 11:07 PM
Fitzy250's Avatar
I fount the port it was hidden next to the fuse box as for the alternator the batt is showing 16.6 volts with the truck off so i checked my pick up and it had 16.6 volts im thinking its time for a new volt meter. i have had it for who knows how long.
Old Oct 18, 2011 | 11:38 PM
OK, but stil not out of the woods. If a 12.6 battery reads two volts high, you are still at like 16 volts which is way high.
Old Oct 19, 2011 | 09:55 PM
I picked up a GreenLee DMM at Lowe's for about $30 that is pretty good. Even has a ruggedized case.
