Direction of steering damper mounting on diff bracket
Old Apr 30, 2018 | 10:41 AM
mirrajumper's Avatar
Default Direction of steering damper mounting on diff bracket
is there any difference in the engagement of the steering damper whether the fat end is on the diff mount of the steering bar?
with this terrafirma 811- should the blue collar be at the diff mount end?
pic attached.
Old Apr 30, 2018 | 03:56 PM
fishEH's Avatar
Makes no difference. Good luck with their bushings, they suck. They'll be cracked and shriveled up within a year.
Old Apr 30, 2018 | 04:20 PM
OverRover's Avatar
+1, the damper direction is fine. As for the bushings (like most TF products) fishEH is correct they suck!!
Get a set of Polyurethane Bushings and you will be very glad you did.
These fit the Damper and the Front Shocks (Upper/Lower) and Rear Shocks (Lower).
> Energy Suspension 9.8145 - Bump Stops - Shock Bushings - 98145. Energy Suspension ENE-9.8145G
Old Apr 30, 2018 | 05:16 PM
Thanks for the tips. Will check out those bushings. What brand of damper did you guys choose?
Old May 1, 2018 | 11:54 AM
fishEH's Avatar
My newer TF one just sh*t the bed. Rough compression and extension, and bushings were toast. Pulled out my old beat up OME damper with original bushings and slapped it on. Good to go!
Old May 1, 2018 | 05:47 PM
A good lesson to always keep the take off parts- you just never know!!
ianmar
Defender
Jan 16, 2018 11:28 PM
newpassion
Mar 2, 2014 12:57 PM
thehun
Mar 10, 2011 08:11 AM
heromanLSU
Jul 17, 2009 10:57 PM
