disco 1
Not the MAF most likely (because of momentary nature). More likely Vehicle Speed Sensor. Or throttle position sensor. Or ignition related issue (amplifier for distributor). MAF very pricey, if you insist on cleaning it do so with a cleaner made for the purpose, and only when the engine is cold. A small wire inside is heated to 350F plus, so cold chemical spray can make it snap.
thanks guys for responding , savhana buzz you were right had nothing to do with the maf. i was checking all the wiring to coil and distributer ,when i found all was well there after you mentioned ignition i decided to check wiring upto ignition switch ,found when i shook the wires going to the ignition switch the engine stuttered .followed all the wires one by one and found the alarm system fitted before has a cut out switch which the wires were touching each other .got that sorted tested the car driving like a dream so far. thanks again all who responded
