disco 1 ac issues
Old Jun 17, 2020 | 04:07 PM
time2disco's Avatar
Default disco 1 ac issues
Hello. Hoping someone can help me here. The AC on my 95 disco is not blowing cold. It is fully charged. There is power to the fuse and relay. Replaced the button as well.
Old Jun 17, 2020 | 05:10 PM
Best4x4's Avatar
Do the Efan's come on? Does the Compressor cycle on?
Old Jun 17, 2020 | 09:26 PM
time2disco's Avatar
No the compressor does not cycle on. I thought maybe not getting signal from the button as it doesn't light up when pressed. The rear fan kicks on and lights up when pressed but the main doesn't.
Old Jun 17, 2020 | 09:42 PM
Best4x4's Avatar
I would check the switch again. I've seen plenty of those things kick the bucket. You might wanna be on the look out for a D2 rear A/C switch assembly (more common to find/source). You can use the locking switch as a direct replacement for your D1 snowflake switch and the slider can also replace the D1 Blower slider. If the system is charged, the pressure switch is good, the efans should come on, and with the snowflake switch engaged the compressor should cycle.
Old Jun 18, 2020 | 08:41 AM
jimvw57's Avatar
There should be a sensor on the AC line that checks for low refrigerant level (pressure) if it is unplugged or defective, system won't work.
Old Jun 18, 2020 | 12:51 PM
stillruns's Avatar
Damn the knowledge on this forum is GOLD!
Old Oct 21, 2020 | 05:21 AM
Eustace71's Avatar
I also have a 95 discovery and had the same problem the relay is down behind the right hand kick panel top right relay is for tne ac
rovingaz Ryan
Sep 9, 2019 01:47 PM
PhilipC
Jul 22, 2018 06:23 PM
bcbp
May 30, 2015 10:36 AM
1998Disco1
Jul 30, 2013 08:33 AM
yatdiscovery
Jul 10, 2010 09:09 AM
