disco 1 ac issues
I would check the switch again. I've seen plenty of those things kick the bucket. You might wanna be on the look out for a D2 rear A/C switch assembly (more common to find/source). You can use the locking switch as a direct replacement for your D1 snowflake switch and the slider can also replace the D1 Blower slider. If the system is charged, the pressure switch is good, the efans should come on, and with the snowflake switch engaged the compressor should cycle.
