Disco 1 driver door handle broken
handle is pretty much an assembly, get a used one, you can switch out your lock tumbler, I just did mine a week ago......not a bad job, i would reccommend disconecting the battery so you dont inadvertently trigger the alarm , remove the inside door panel / handle / speaker etc to get at it
If its unlocking then the superlock is disengaging (**** won't come up otherwise). It could be that the mechanism is jammed. When I took mine apart I didn't reassemble it correctly the first time and a spring came loose preventing the latch mechanism from moving freely (I used a screwdriver to engage and disengage the latch instead of closing the door). Either way your going to have to reach in and unlatch it by feel. Its been a while but I remember that if you loosen a couple of screws for the frame you could move it slightly out of the way.
awoods82
03-26-2012 10:00 AM
