disco 1 fuel pump replacement "help"
Old Jan 2, 2013 | 11:20 AM
gman21's Avatar
Default disco 1 fuel pump replacement "help"
i have a 99 disco 1 and i believe my fuel pump went out i was driving to the store and got out and when i got back in and tryed cranking it it wouldnt start i didnt think nothing of it and i took a can of starter fluid and sprayed it in the manafold and bamm it fired right up then died so i knew i wasnt getting no fuel so i turn the key off and undone the back side of thge fuel filter and turn the key on and off no fuel shooting out so i assume its the fuel pump so i took it out and tested the "double plugs" on the top of the assemly and they have fire to both plug that rules out electrical problem so my real question is !!!!! what model fuel pump can i buy at a auto parts store that will take the place of the factory one and work the same ????? i was told a 80's model chevy pickup pump will work ? is there any truth to that ? or where can i buy one i need it asap im without my ride help thanks !!!! and if you just wanna call or text me its 8632541147 yhanks a bunch
Old Jan 2, 2013 | 11:36 AM
fishEH's Avatar
I used one from an '87 Chevy Astro van, but many models will work.
Be aware, the part you get from the parts store is just the pump. You'll have to reuse the housing. Its a very good idea to change the pump sealing ring and the reataining ring(if its in bad shape). But if you're in a hurry you may not be able to get those parts in time.
Old Jan 2, 2013 | 12:03 PM
gman21's Avatar
ok i called advanced and they said a 4cyl or a 6 cyl im thinking you got the 6 cyl correct he said the kit in 57.01 and includeds new sock and pump and o rings thats should do me right ?
Old Jan 2, 2013 | 12:09 PM
bushpilot's Avatar
maybe this will make it simplier for you.
pump - AC Delco part number EP241
strainer - AC Delco part number TS7
Hope this helps.
Old Jan 2, 2013 | 01:28 PM
EricTyrrell's Avatar
https://landroverforums.com/forum/discovery-i-39/new-$20-fuel-pump-53083/
Old Jan 2, 2013 | 02:03 PM
JPSpen's Avatar
If you find your housing is badly deteriorated..
Trevor at www.rovahfarm.com
Has the complete unit for $109..
He also has the seal...
John
jycsalas
May 23, 2019 03:02 PM
Travelor
Sep 24, 2015 06:11 PM
andrewed
Apr 27, 2011 11:38 AM
JumPeR04
Apr 7, 2011 09:52 PM
03RRDude
Oct 26, 2009 07:18 PM
