Disco 1 problem
Old Jun 24, 2012 | 01:26 PM
Captian Adrianus's Avatar
Default Disco 1 problem
1995 Discovery, 3.9, automatic transmission. 186,000
6 months ago I overheated while out in the desert. I changed the thermostat and it was relatively fine on the surface streets. it would still overheat while off-roading. At one point I overheated 6 miles out in the desert. Needless to say, I warped the heads driving it out of the desert. I rebuilt the top end of the engine. Sent the heads out for milling and re-building. I got it all back together and it runs incredibly smooth and quiet. The problem is this....sometimes when I come to a stop the engine stalls. It starts right back up and is fine. It did not do this before I did the rebuild.
On a side note: does the discovery really need the rover thermostat with the sleeve on it or will one with the correct temp rating work? I had to remove the one I replaced as it was overheating with it in. It does not overheat without a stat in.
Old Jun 24, 2012 | 03:21 PM
u can use $10 stat in a D1 - nothing special, I run a 180F stat, 180-183 at 60 mph 92F outside. If u run with no stat, about 145 - 155, and u will have low mpg
Old Jun 24, 2012 | 04:05 PM
Your radiator is clogged.
I run a 195*F t-stat from AutoZone.
If it now stalls after the work was done then either you have a vacuum leak or the IACV is bad/not hooked up.
Old Jun 24, 2012 | 09:33 PM
Default thanks.
Thank you both. I will pull the radiator and send it out. She overheated with the new stat in but is fine when i took it out. i did find a vacuum leak that solved my stalling problem....again, Thank you.
Old Jun 24, 2012 | 09:44 PM
In my farming area, an indy rad shop will hot tank flush the radiator, plus unsolder a side tank and rod out the calcium. Cost me $75 last time. Look for small places that do ag and construction gear, a Rover radiator is a teacup to them.
Old Jul 1, 2012 | 12:26 PM
Just to let you know, I pulled the radiator yesterday and almost half of the fins were packed solid with dirt and bird feathers. I think I can safely say this is the cause of my overheating problem.
Again, thank you for the help.
Adrianus
Old Jul 2, 2012 | 06:43 AM
DiscoJag's Avatar
You gotta watch out for those road runners !
Old Jul 2, 2012 | 06:57 AM
antichrist's Avatar
That's pretty hot.
Land Rover specs fully open at 88C, which is 190F. All the domestic 190's I've tested start opening at 190. That's why I run a 180.
Old Jul 2, 2012 | 09:28 AM
EricTyrrell's Avatar
I just put a 195 in mine and it hovers around 194-195. This highest it normally gets is <208. Thermostats may vary by manufacturer though.
Old Jul 2, 2012 | 09:32 AM
roverman2010's Avatar
Default stalling
When the last time you cleaned the stepper motor?
When driving in the dusty conditions in NM I find it gets dirty fast.
