Disco 1 Transfer case only works in high unlocked
Old Mar 26, 2013 | 04:45 PM
Lord Wert's Avatar
Exclamation Disco 1 Transfer case only works in high unlocked
Hello fellow rovers.
Whenever i try to switch my gearbox out of high unlocked im getting no drive reaction but only get a thump sound and a rev bounce. almost like taking your foot off the accelerator rapidly over and over. i Cannot get the high or low diff locks to eng either. This disco drives and operated great in the standard high unlocked setting. Id like to be able to use these other transfer case features since i live in the mountains and get pleanty of snow. I fear that the transfer case is blown. The transfer case shifter does not put up abnormal resistance to get into these positions and im fairly sure im getting the shifter all the way in position.
any insight would be greatly appreciated
96 D1 SD 166K
NEW TRANS
Hancook ATM 235/75/16
lucas gear oil
full synth oil
all tune ups on time
rebuilt door springs and window regs
ODBii on board bluetooth torque scanner
In the market for OME suspension equipt
Old Mar 26, 2013 | 05:31 PM
Scope's Avatar
When you shift into low does your light on your dash come on?
Old Mar 26, 2013 | 08:51 PM
jfall's Avatar
First -
Open up the filler on the transfer case and fill it full of oil.
It may be dry.
Putting in oil may bring it back to life.
Then after driving around in HI range you can try LOW again.
Or, the RUST has just corroded the control linkages.
Old Mar 26, 2013 | 10:03 PM
Disco28's Avatar
Highly recommend checking the oil asap as jfall said. Most T-Cases leak and eventually run dry like mine did and imploded itself Also there is a clevis pin that connects the linkage to the T-Case that could be broken/bent/missing/rusted which wouldn't engage the remaining positions. Mine was barely holding on when my original T-Case did work and would only engage in High Unlocked.
Old Mar 26, 2013 | 10:29 PM
Lord Wert's Avatar
No lights when put in other positions.
can't seem to locate the tcase filter. I only see the oil filter. What does the filter look like? Thanks!
Old Mar 26, 2013 | 11:05 PM
jafir's Avatar
No filter.
Old Mar 26, 2013 | 11:12 PM
Lord Wert's Avatar
Sorry. I misread. should the tcase be filled with the dex2 trans oil?
Old Mar 27, 2013 | 06:50 AM
Disco28's Avatar
A lot of us on here use 75/140 in the T-Case without any other additives. Makes for a quiet ride and increased protection against wear.
corbinwelter
Dec 28, 2014 04:19 PM
All4uonline
Apr 19, 2010 05:43 PM
whurst79
May 31, 2008 05:20 PM
