Disco 2 Brush Guard on Disco 1
I just measured the mounting tabs on the brush guard; inside to inside they are 26.5 inches whereas inside to inside on my frame measures 24.5....
Also same issue as mentioned previously, the two bolt holes in the tabs are parallel with the ground and the frame bolt holes are up and down.
Guess it's no surprise that Land Rover changed the design that drastically between the Disco 1 & 2.
It really wasn't a drastic change in that respect. Are you sure that guard is from a D2? I have personally used D1 and RRC and D2 bumpers/guards with zero modification. This is the same truck with a winch bumper I personally removed off a D2.
![Name: 2013-12-21221148_zpsfe37195a.jpg
Size: 103.3 KB](https://landroverforums.com/forum/attachments/discovery-i-39/36297d1501365817-disco-2-brush-guard-disco-1-2013-12-21221148_zpsfe37195a.jpg)
I also test fit a D2 bumper on my RRC. It fit perfect. They all interchange. Some may fit better than others on the body lines. But they all mount the same.
smokinwheels
05-25-2021 11:11 PM
christiansmith6
01-07-2014 07:46 AM
SpeedAgent
03-16-2008 11:06 PM
DiscoMikeandMike
12-17-2007 01:37 PM
