Disco '97 electrics
I have a disco'97 that is giving me grey hairs. She runs well and will suddenly stop running. The engine turns but i have no ignition. Fuel pressure is good. Normally after a few tugs on the coil wiring she starts again until next time. Coil has been replaced and all wiring connections re-made. Sometimes she wont start until i tug the coil wiring harness. Super frustrating.
![Mad](https://landroverforums.com/forum/images/smilies/MMiQGA5.png)
Sensor is hard to reach with big hands, best to plug in and let it hang to install. Every little nut and spacer must go back on in exact sequence, spacing is critical. Diagnosis is check for spark when this happens, no spark points at CKP. Some have poured cold water on it and reset it. Here's some pages on it.
Indeed. It is "triggered" by the nose of the sensor (a coil of wire around a metal shaft) being passed by metal tabs on the reluctor ring. These whiz by millimeteres away, and cause the generation of a signal which is used to control timing in the computer. If the signal degrades due to coil wires shorting or opening up, or metal flakes stuck to the sensor rod (ferros contamination) or bent reluctor teeth, timing will suffer. Sometimes chucks of starter teeth can work their way in there and cause problems. Since your problem is off and on, would not suspect reluctor disk teeth. On a D2 they went to a different style disk that is drilled and milled out, rather than stamped and bent meal tabs.
Here's some pix:
Here's some pix:
Does your truck have a distributor for the ignition? If so, won't have CKP sensor. The distributor systems have an ignition amplifier module that can heat up and drop out.
If you don't have a distributor, look at this picture. The connector leads down to a small cover over the sensor. PITA to get at. Should be left side of engine.
The RAVE manual does not show alternate layout for this device based on LHD or RHD configurations.
