Disco I, all of a sudden won't idle.
Old Oct 8, 2015 | 09:07 PM
Gmacfilm's Avatar
Default Disco I, all of a sudden won't idle.
I have a 1994 Disco I, with 5 sp. manual transmission. It has sat inside my studio building for a while now. I decided to charge the battery and start using it a bit, now that gas prices are lower. It worked fine for the first couple of trips out, but today, all of a sudden, it won't idle. I had to keep pressure on the gas pedal to keep the engine running. It runs fine otherwise, but pull up to a stop, push the clutch pedal in, push brake on, and the idle goes down and the engine dies. I made a temporary "emergency" adjustment by adjusting the throttle cable to the engine, and that works, but not optimally. Any ideas? I don't seem to be getting any enrichment for cold starts/running. This is a fuel injected vehicle.
Old Oct 15, 2015 | 11:13 AM
Gmacfilm's Avatar
It was the idle air control valve, as I suspected.
Old Oct 15, 2015 | 07:55 PM
ihscouts's Avatar
Was it crusted and you cleaned it or did you replace it with new?
Snafu / Disco Fries
Jun 20, 2011 08:26 AM
booper169
Nov 9, 2010 09:10 AM
pierce2988
Sep 4, 2010 06:29 PM
Wanderer
Jan 5, 2010 10:45 PM
Camdisco24
May 9, 2008 10:26 PM
