Disco I fault code 34 HELP
Old Feb 23, 2013 | 11:23 AM
den_85's Avatar
5th Gear
Angry Disco I fault code 34 HELP
Hi all,
I´m new to the forum and this is my first post.
I own 1995 Disco with 215K miles (major engine rebuilt done 6 months ago). Yesterday driving home from work the CHECK ENGINE light came up, so I looked at the On-Board Display Unit and it shows code 34. Doing some research I found out that it refers to Fuel Injectors being clogged or stuck open on Bank A. Can anyone point in the right direction on how to fix the issue? would be just a matter of cleaning up the injectors or would it require a lot of money to fix?
A few days ago I let the fuel tank almost empty and probably some debris got into the injection system.
Any help is greatly appreciated. Thanks
Old Feb 23, 2013 | 02:43 PM
ihscouts's Avatar
Stuck injector open/closed. Remove each one on bank a and shake it. If it rattles it's working, if not it's stuck. They do break the pintles...... and the injector screens are so small if anything was to get by the pump screen and then the fuel filter they would catch it. Did you have the injectors cleaned/checked/balanced during your "major" overhaul? How about the rail since it rots from the inside out?
06Range
May 8, 2013 09:01 PM
sayeedA
Nov 15, 2011 11:02 PM
jason9500
May 12, 2008 08:21 AM
Rover5150
Nov 28, 2007 09:57 AM
