Disco rough RPM patch, hard shifting transmission
Old Mar 10, 2011 | 10:20 AM
bschoole's Avatar
Default Disco rough RPM patch, hard shifting transmission
Hi everyone.
So i bought a 98 Discovery I, it had blown head gasket and was seized from hydrolocking, so I opted to buy a used engine and throw it in.
Well it is now replaced and everything is hunky dory except acceleration is rather rough.
The car ideals normally, and accelerates fine except between about 2-3K RPM, it gets rough and seems to loose power, once it gets past that it gets buttery smooth and starts pulling well. It has new plugs and wires, I haven't had an opportunity to check everything yet, there is no CEL. Do these trucks have timing chains or belts? Or is it maybe something simpler then that?
Also on another note, the transmissions seems to shift hard when shifting at low RPMs, it shifts smooth if I am pushing it. What transmission fluid do you use when changing?
This is my play toy second vehicle so I am not really rushing to fix it all at once. Just wondering if you have any suggestions on where to start looking. I am outta state right now, so I won't be able to look at it till probably saturday or sunday.
And can I say, I am super excited about owning this vehicle!
Old Mar 10, 2011 | 01:36 PM
AtlanticBritish's Avatar
LR Forum Vendor
Perhaps try a compression test to see if the cylinders are running evenly...
__________________
Old Mar 10, 2011 | 01:38 PM
calebbo's Avatar
Originally Posted by AtlanticBritish
Are you actually from the website or, as I like to call them, free-tisement? Like the guys with GIANT Honda symbols on the back or their windshield, but the online version
Old Mar 10, 2011 | 02:00 PM
Dodger's Avatar
Is the kickdown cable adjusted correctly? There are very specific measurements in the rave manual. I had to adjust mine twice before I got it right. Check your throttle position sensor.
Old Mar 10, 2011 | 03:47 PM
bschoole's Avatar
I will take a look at the kickdown cable, very possible its off, didn't even think about it, thanks.
I was kinda thinking about the TPS, I have a complete set of extra sensors from the old motor, I am going to go and clean up everything, maybe even try switching the TPS and see if symptoms improve. Its a very specific RPM range it occurs in, it seems no matter what speed or what throttle application ... which is why i was kind of considering it being a timing issue ... although you would think it would affect more then a range of 2200-2900 rpm if it was that.
If that doesn't improve anything, I will go get a compression test and see if anything is off.
Old Mar 10, 2011 | 06:57 PM
Danny Lee 97 Disco's Avatar
It seems to me if it were related to the timing or something of that nature, it would be throughout the RPM range. The fact that it is rough for that 2 to 3 K rpm range , then "Buttery Smooth" is somewhat puzzling.
Did you go thru the used engine prior to replacing it to check stuff or did you just install an unknown engine?
Old Mar 10, 2011 | 06:58 PM
Who is this new AB Guy? What is up wid dat?
Old Mar 11, 2011 | 07:18 AM
LR Forum Vendor
Hi all... My name is Chuck from upstate NY... Love Rovers and work for Atlantic British... Glad to be on the site with fellow enthusiasts!
__________________
Old Mar 11, 2011 | 09:06 AM
Dodger's Avatar
how about a bad coil pack? mine is a dizzy model, but my wife's old expedition did something similar. We replaced the coil packs and it was all good.
Old Mar 12, 2011 | 10:11 PM
bschoole's Avatar
Well guys, I am going to work on it tomorrow, Just got back from new york tonight, 1300 mile drive is no fun.
Was glad to find it started right up after a week of sitting. It actually felt somewhat better when I drove it around, maybe its just wishful thinking.
I will let everyone know what I discover tomorrow, thanks for the advice!!!
Dan7
Dec 3, 2014 07:47 AM
KlamathMatt
Feb 26, 2013 01:25 AM
seminolef1
Nov 1, 2012 03:01 PM
Allenhartwig
May 15, 2012 04:11 PM
gavone1976
Mar 23, 2011 11:05 AM
