Disco suffered a stroke.
Old Jul 3, 2013 | 05:18 PM
bcbp's Avatar
Default Disco suffered a stroke.
Just finished splicing in my u haul trailer wiring harness and testing the lights on my camper. I realized the right side running lights won't come on, tail, bumper, and headlight (when turned to the first ignition position). Fuses look fine and so do the bulbs. It's a 4 pin connection. Anyone have this happen?
Old Jul 3, 2013 | 05:40 PM
bcbp's Avatar
Just found a 10amp fuse blown. It was tricky to see at first.
Old Jul 3, 2013 | 08:04 PM
formel3's Avatar
U Haul wired me up before the trip that just blew up my trans, keep a TON of fuses on you, I was blowing one every 30 minutes. Take the wiring off soon as you're done.
Old Jul 3, 2013 | 10:21 PM
bcbp's Avatar
Oh wonderful, sorry to hear about your trans. Do you know which color on the land rover side is the constant 12volts? My set up is a 4 flat but my trailer has a fifth wire (black) that is used in the porch and interior light.
Old Jul 4, 2013 | 12:02 AM
On the Rover side the pin #1 is a purple/brown and it runs back to the 20 amp fuse F6 in satellite fuse panel 2 under dash.
Old Jul 4, 2013 | 04:45 AM
antichrist's Avatar
Obviously it was done wrong. I've never blown a fuse related to trailer wiring on any vehicle I've wired. Then again, I've never let a shop do the wiring.
If you didn't have the problem before the wiring, and you did it like this: https://landroverforums.com/forum/di...29/#post179231 then you probably have a fault in the trailer.
Any axillary lights, like interior lights, should be wired to the constant power circuit, the purple/brown.
Old Jul 4, 2013 | 07:08 AM
bcbp's Avatar
Antichrist the problem was my wiring, thank you for the write up.
Old Jul 4, 2013 | 06:33 PM
formel3's Avatar
Yeah, that was my mistake, I was just too freaking hot to deal with it myself. Still, bigger problems arose on that trip...
Old Jul 4, 2013 | 06:41 PM
Sam95disco's Avatar
I had the same thing happen, dumb how one fuse will cause all that bs.
Old Jul 5, 2013 | 07:26 AM
antichrist's Avatar
Originally Posted by Sam95disco
...dumb how one fuse will cause all that bs.
Maybe. Personally I'd much rather have a blown fuse than a fire, which is the alternative.
brightbill
Engine & Internal
Sep 22, 2010 04:12 PM
whoelse
May 10, 2005 02:04 AM
