Disco wiring diagram
Old Mar 3, 2012 | 12:45 PM
Disco_stu97's Avatar
Default Disco wiring diagram
Does anyone know where I can download a wiring diagram for my Disco 1?
I've searched for one but haven't had much luck.
Old Mar 3, 2012 | 01:02 PM
EricTyrrell's Avatar
http://www.landroverresource.com/rave.zip
Download the RAVE there. It contains multiple manuals inside. One of them is the ETM (Electronic Troubleshooting Manual).
Old Mar 3, 2012 | 03:06 PM
Danny Lee 97 Disco's Avatar
Read the ETM entirely. It explains their version of a wiring diagram. It is different from any schematics I have ever used in over thirty years of electrical systems experience.
Old Mar 3, 2012 | 03:08 PM
In particular read the initial part of the manual that describes the color code. What are you working on - perhaps we can point you in the right direction.? Also an on-line source in link below.
Old Mar 3, 2012 | 07:42 PM
I have something draining my battery and the previous owner did some "creative wiring" to replace a bad a/c switch.
Old Mar 3, 2012 | 07:56 PM
MJy advice is remove all mods made by PO and start from that point on restoring correct functionality.
These wire harnesses are poor example of workmanship to say the least. Mods give you a real unknown factor.
Old Mar 4, 2012 | 10:04 AM
That's what I plan on doing, just needed a wiring diagram for reference. Also my radio doesn't turn off when I shut off the vehicle, I have to turn it off manually. There doesn't seem to be any wiring mods made to the radio. Any insight? Thanks.
Old Mar 4, 2012 | 10:21 AM
Radio gets power for the control head all the time through one fuse (keep memory and anti-theft code alive) - F6 in the satellite fuse box. F3 in the larger under dash fuse panel is the switch leg of power to the control head. Perhaps up stream the ignition switch or a relay. Or previous owner wiring you are yet to "discover"...
Got your security code for radio written down somewhere?
Desert Roadrunner
Oct 1, 2010 12:23 PM
ogden45
Dec 28, 2008 05:17 PM
mellyagaunce
Dec 5, 2008 08:03 PM
yarddawg
Jan 29, 2008 05:56 PM
saka24
Audio/Visual Electronics
Aug 11, 2005 07:19 PM
