disconnected fusebox connections
Old Mar 16, 2012 | 04:18 AM
fezzr's Avatar
6th Gear
Default disconnected fusebox connections
Can anyone help identify some of my wiring woes.
Have just brought the vehicle and found two plugs floating loose in front of the fuse box. Can someone identify where they should be plugged in?
One is green and the other is green and blue.
The vehicle is a 97 chassis disco RHD 300tdi auto
Old Mar 16, 2012 | 05:13 AM
Yellow casing is airbag wire of some sort. Does your SRS airbag light come on at bulb test when truck is started each time, and then go out?
Old Mar 16, 2012 | 04:54 PM
fezzr's Avatar
6th Gear
Nope no airbag test light, they booths look like they've been used, previous owner said it had a turbo timer that he removed, but he did a poop job by the looks
Old Mar 16, 2012 | 05:35 PM
Air bag warning light is disconnected, and perhaps some others. Check RAVE set of owner's manuals for your truck and see which lights should be on at power up. Example would be oil pressure warning light, battery warning light, check engine light, etc.
Old Mar 18, 2012 | 12:20 AM
fezzr's Avatar
6th Gear
The warning light wasn't disconnected, when both the cables were back in there correct locations the warning lights operate as expected.
Will update picture with correct locations in case anyone needs it in the future
martin
Aug 21, 2012 06:18 PM
JBreckeen
Oct 4, 2011 06:57 PM
christocord
Jan 28, 2008 08:34 AM
awpti
Sep 7, 2007 01:25 PM
roodog
Defender
Feb 17, 2007 04:22 AM
