Discovery 1 complete power blackout
Old Oct 24, 2018 | 12:59 PM
Crunkgringo's Avatar
I did have to clean and replace the battery terminals a year ago or so because they were all corroded and janky. I used the autozone duralast terminals and they seem to be doing real good. Another way I knew my battery was bad was when I hooked up the charger it would only "charge" for about 5 minutes then say the battery was full. The voltage was only 11.8 or something after it "charged" and that is how I knew it was a battery. The voltage should be at 12.5-13v when its fully charged.
And agreed, check your grounds and look at the negative cable right behind the battery. There is a bald spot were the wire connects to a clamp on the wheel well. Make sure the wire is still solid there and of course at the starter.
hankeester
Feb 18, 2018 03:47 PM
Lost
Jun 11, 2016 09:21 PM
nooath
Apr 27, 2014 02:53 AM
FieryRebel28
Sep 15, 2012 04:26 AM
sleeping dog
May 2, 2007 02:58 PM
