Discovery 1 Dying
Old Apr 17, 2012 | 01:20 PM
Chris-bob's Avatar
Isn't your ECU under the bonnet? Should be. With fuel injection, you will have an ecu.
Old Apr 17, 2012 | 01:26 PM
Tony Morrish's Avatar
Nothing under the bonnet that even slightly resembles an ECU, 3 mechanics and myself have checked and we can't find the thing anywhere?
Old Apr 17, 2012 | 01:39 PM
Chris-bob's Avatar
Inertia fuel shutoff switch
The inertia fuel shutoff switch is a mechanically
operated switch, located on the bulkhead adjacent to
the washer reservoir under bonnet [hood].
The switch is normally closed and is in line with the
fuel pump. In the event of a sudden impact the switch
opens, and disconnects the electrical feed to the fuel
pump. The switch is reset by pressing down the
button.
WARNING: Check the integrity of the fuel
system before the inertia switch is reset.
Relay modules
The two multiport fuel injection relays are located in
the RH footwell area behind the ’A’ post panel. The
main relay module is energized via the ECM when the
ignition is switched on and supplies current to the
multiport fuel injection system. The fuel pump relay
module is energized by the ECM which in turn
operates the fuel pump to pressurize the fuel system.
Old Apr 17, 2012 | 01:40 PM
Chris-bob's Avatar
ECM should be on the right inner wheel well next to the firewall. Under a little piece of plastic masquerading as a cover.
Old Apr 17, 2012 | 01:48 PM
thebloody's Avatar
Originally Posted by Tony Morrish
Wow cheers guys keep it coming LOL
I have had the gas system checked out and all is ok with that, my first thought was that the injector simulator was packing in but no.
I don't have a crank sensor on the 1995 v8 3.9, but thanks for trying. At the same time, interestingly i cant find the ECU and i am beginning to think it doesn't have one as such, i have found a bunch of contactors/relays etc in the drivers side foot well, side panel. I have checked these and they seem to operate properly.
Ah ok, they must of added them when they started putting the 4.0L in the D1.
Old Apr 17, 2012 | 02:05 PM
Chris-bob's Avatar
ENGINE CONTROL MODULE (ECM)-14 CUX
Service repair no - 19.22.34
NOTE: The ECM is not serviceable, in
event of unit failure it must be replaced.
Remove
1. Remove the fascia right-hand closing panel.
2. Remove the right-hand footwell side panel trim.
3. Disconnect battery negative lead.
4. Release ECM plug retaining clip.
5. Maneouvre the front of the plug (in the direction
of the bold arrow) and detach the other end of
the plug from the retaining peg.
6. Release the two screws securing the ECM to the
right-hand footwell side panel.
7. Withdraw the ECM from the clip.
Refit
8. Refit the ECM securely in the clip and fit the two
screws.
9. Reconnect the ECM harness plug. Ensure that
the plug is pushed firmly into its location and that
the retaining clip secures the plug in position.
10. Reverse removal procedure.
Old Apr 17, 2012 | 02:06 PM
Chris-bob's Avatar
When did this problem start happening? Did anything lead up to it?
Old Apr 17, 2012 | 02:09 PM
Chris-bob's Avatar
How is your ignition switch?
Old Apr 17, 2012 | 03:05 PM
I will look for the ecm again but i have checked this area with no results.
the problem started around 5 weeks ago with the car juddering when excellerating or driving up hill, i found the springs in the dissi for the advance and retard had broken, that's when i replaced the dissi. As i do a large amount of miles i also replaced the coil, amp, ht leads etc.
The car ran really well for 2 weeks after that then this problem began last week end, suddenly, no warning lights come on, no buzzers, nothing untoward at all just suddenly dies a death. I initially thought i had replaced the amp incorrectly so i replaced it again just Saturday gone just in case but no luck. car still dies after 20 minutes of driving.
Old Apr 17, 2012 | 03:06 PM
Ignition switch seems fine, operates smoothly
