DIY D1 Cargo Net
Old 08-03-2021 | 05:47 PM
Shiftonthefly1's Avatar
Default DIY D1 Cargo Net
I like having a cargo net for camping ever since I discovered using it on my Xterra. Unfortunately no such product is readily available for a D1. I've seen multiple options for the D2 but for whatever reason all the sales reps say it won't work even w modification. So I decided to make my own using a universal divider available here:
https://raingler.com/collections/uni...nt-barrier-net.
For me this was the size to use as I installed it, it allows me to also use it vertically once I install some hooks low to the floor. This was a lot of trial and error guess work and hopefully this will speed this up for anyone wanting to do the same.
I mounted it to the rear grab handles at the front of the net and then at the rear is where the work began. I hate cutting/drilling if I don't have to. So I decided to use the factory holes in the Alpine window trim panel. Once the push clips are removed you can see they have a plastic nut-certs.For me this would not have been strong enough. So I used lag style hooks to test fit and mock it up.
Next I drilled out the holes needed for the inserts and the original plastic insert in one go. I used 5/16 eye hooks that required a 1/2" hole. I figured these each have a 90lb weight limit and there's no way I'm putting anything close to that heavy up there. I also wanted these hooks to hold up the trim pieces like the original Christmas tree push pins did. So I dialed back the nuts and used a washer so I could adjust the amount of tightness on the panel itself. I think it came out really good. I'll mess around w it and get it more taught. I mocked up what I usually keep up there during a camping trip. It's got two jackets. My back packs, two folding chairs and three rolls of paper towels.
Old 08-04-2021 | 11:39 AM
logan_gibson's Avatar
I was just doing some measuring for this, thanks!
I had the same idea about using those existing holes, looks like it works well!
Old 08-05-2021 | 02:04 PM
No prob. The width is a little much for the Disco but now that can be messed with. The hardest part for me was getting that rubbery plastic panel on and off w out damaging it. Here it's 115 during the day so that glass area is cooking. I also need to make some sort of shaded insulation for the sunroofs. I hate sunroofs.
drcoop
03-26-2024 07:51 AM
Urban Panzer
12-06-2021 12:25 PM
A Faceless Man
05-10-2021 10:00 AM
ATLRVRS
02-13-2019 09:21 PM
Jeff Blake
05-16-2018 01:50 AM
Quick Reply: DIY D1 Cargo Net
