Do It Yourself D1 Seat Repair
Old Feb 12, 2011 | 09:49 AM
jacumja's Avatar
tweakrover
Yes, lets do that, lets do exactly that. Naahh I just want to check out the out banks at least once. Supposedly there are all sorts of camping and places you can drive out on the beach and set up at type of stuff.
Old Feb 12, 2011 | 10:03 AM
fire's Avatar
6th Gear
As we say in South Africa " n boer maak n plan". Which means a man makes a plan. Looks good!!!
Old Feb 12, 2011 | 12:13 PM
jacumja's Avatar
Heres the finished result. The cloth seat cover is still loose but the pad is where it should be. I think the cover is loose from lazy previous owner sitting in it while it was stretched down to the floor.
Old Sep 24, 2012 | 08:48 AM
rrc.swb's Avatar
I stumbled across this post and wanted to let you guys know that there is a very good fix for this.
I've done it on both my Disco's
Discovery Seat Fix: now for sale
Old Sep 24, 2012 | 01:41 PM
Banzai Jimmy's Avatar
Only problem I have with the canvas solution is the elimination of any give.
I'm one of those who pops in ones I grab from the 'yard.
Old Sep 24, 2012 | 02:13 PM
jafir's Avatar
exmoor now sells replacement foam and the diaphram
Re-Trim Kits, Foams, Diaphragms
Though some have found, at least for the D2, that the foam is cheaper for oem from the uk. Not sure about D1 availability of oem.
Old Jun 19, 2014 | 08:16 AM
dagr8tim's Avatar
Not to drag up an old thread, but I did something similar in a Jeep. Most aftermarket suspension seats use nylon paracord for the suspension.
Considering that, and the fact that I had several hundred feet of 550 lbs test para cord that I used to make bracelets, watchbands, dog collars, and leashes out of. I decided to try my hand. Basically I ran it across from side to side with alittle drape to it. This firmed up the seat quite a bit.
Old Aug 4, 2014 | 12:29 AM
Phidol's Avatar
could be the sewed cloth with plastic inside the seat cover was not inserted in the slot of the foam, which hooks the cover in place.
Wildrider
Mar 6, 2011 11:25 AM
n1keaddict
Feb 19, 2011 10:36 AM
hazletbassist89
Apr 12, 2009 01:26 PM
usmc_mwroseberry
Feb 19, 2009 08:16 PM
johnkbl
Apr 11, 2007 07:01 PM
