Doh!
Old Nov 20, 2016 | 07:16 PM
stillruns's Avatar
Default Doh!
I've yet to find where it is coming from. There must be a leak or something that shoots it right to the top of the battery bc there isn't radiator fluid anywhere else but there. And around the battery pan. Green means coolent right?
Old Nov 20, 2016 | 10:10 PM
XCELLER8's Avatar
get rid of that black plastic reservoir tank and cap.....they are known to crack and /or leak...get the updated white tank and a new cap while you're at it....it'll pay for it self in spewed coolant costs......
Old Nov 21, 2016 | 09:21 AM
stillruns's Avatar
This is why I come here. Thanks for the info. Next question of course, where is the best place to purchase one?
This from Rovahfarm?
Radiator Expansion Tank Disco I
Ref: PCF101590 / Price $32.95
Old Nov 21, 2016 | 10:11 PM
XCELLER8's Avatar
that'll work !
Old Nov 22, 2016 | 04:29 PM
stillruns's Avatar
Originally Posted by XCELLER8
that'll work !
Found the crack in the tank. See photo. This is where it is spewing from.
Old Nov 22, 2016 | 06:51 PM
jimvw57's Avatar
yup, shows up when it is under pressure. Got mine off of Ebay. no problems since. Make sure it is the white one, the black ones tend to break easily.
Old Nov 22, 2016 | 09:25 PM
stillruns's Avatar
Placed order for new one today. What exactly do I need to be aware of when removing the two hoses attached to the current black tank? Do I need to drain any of the fluid? Can I use the existiing hoses? Replace any of the coolent? Ive not done this before and don't want to screw it up. Thanks
Old Nov 22, 2016 | 09:54 PM
XCELLER8's Avatar
no big deal at all....you'll lose a little coolant as you take the hoses off but not normally an issue....easy fix, just look over the hoses good................and have you ever replaced the thermostat ? while you've got the system opened up now'd be a good time...most auto parts stores would have that in stock, when its all back together bleed it and drive it like ya stole it .............
Old Nov 28, 2016 | 05:08 PM
stillruns's Avatar
The new resevoir came in but with a broken piece. This thing looks like it has been sitting in a box for 20 years, brittle i suppose.
Old Nov 28, 2016 | 05:59 PM
OverRover's Avatar
WOW that really SUX!
If you don't mind spending 4X the money you could always get this piece of bling > 4750 Range Rover Classic Allisport Aluminium Header Expantion Tank 200 300TDi V8 | eBay
Solves the problem. I don't know about you, but that's too spendy for me!
