Door Locks / Key fob doesnt work
Old Mar 18, 2019 | 11:42 AM
WeekendWarriors87's Avatar
Default Door Locks / Key fob doesnt work
I cannot seem to figure out why my key fob will not lock or unlock any of the doors. Its a 96 disco 1 v8, the locks move up and down manually but the key fob will not do anything at all. I already changed the battery in the fob. I have done a bunch of reading and cant seem to find too much about this issue, anyone know what it might be? ( I have not tried using the key in the door, as I heard that this can cause a lockout and prevent you from being able to start the car, if this is not true then someone please confirm this so I can give this a shot)
Thanks!
Old Mar 19, 2019 | 08:12 AM
No one has any idea what this might be?
Old Mar 19, 2019 | 09:29 AM
Paul Grant's Avatar
Did the remote ever work on the central locking? Is the inability of the fob to work a new development or has it been ongoing since you got the truck? If it's ongoing, someone may have bypassed the alarm module because of a failure. If it's only been since, say, the battery in the fob died, you may just have to resync the fob to the module. The procedure is best done with two people and can easily be found on the web.
Old Mar 19, 2019 | 09:41 AM
I only bought the truck a few months ago (in a non running, nothing working condition) and am restoring it. The fob has not worked since I bought it, so I am really not sure.
Old Mar 19, 2019 | 08:38 PM
Ankeneering's Avatar
There is a company in the UK that will send a dongle to plug into the OBD2 port that will allow you to sync the alarm and the fob.I had to send the dongle back or loose a deposit but it took two minutes. I'm sorry I don't have the name of the company in front of me but I found it with some googling a couple of years ago.That is not an exact answer to your question I know, the power lock mechanisms in mine sound like they are getting tired and slow, I personally don't use the fob to lock.
Old Mar 19, 2019 | 09:39 PM
stillruns's Avatar
Toss the fob and this. Problem solved.
Old Mar 20, 2019 | 06:12 AM
So its possible to lock the whole car with the key in the driver door without immobilising the vehicle? And thanks Ill check it out to see if thats the problem.
Old Mar 20, 2019 | 02:35 PM
OverRover's Avatar
If you want to lock the doors without activating the alarm then yes, try this...…..
Old Mar 21, 2019 | 06:05 PM
Thank you! I went out and tested it, I realised that the driver door lock actuator does not work and this is likely why the other doors dont lock. Also, this may be a dumb question, but your response references a button inside the door, I cant find any button on the interior that resembles a lock button and no button at all on the front door??
Old Mar 21, 2019 | 08:18 PM
OverRover's Avatar
That description from LR can be confusing, but the "locking button" is just referring to the lock lift/****....
