Door sensor problems
Old Aug 16, 2024 | 10:08 AM
fowlerjk04's Avatar
Default Door sensor problems
On my Disco 1, none of my interior lights work when the doors open (switch to DOOR) but they work when switched to ON. I've also noticed that I don't get door ajar alerts, nor does the alarm do anything when attempting to open the doors when armed. So it's a systemwide thing as opposed to a single switch or sensor.
Am I correct in thinking this is a BCU issue? I have a Nanocom and could check programming. What should I be looking for otherwise?
Old Sep 9, 2024 | 08:55 AM
WaltNYC's Avatar
A D1 does not have a BCU. That began with the DII.
As for door switches and the alarm... the first step is test continuity with a multi meter. That can be a rather tedious task.
Old Sep 12, 2024 | 02:24 PM
disco96sd's Avatar
probably just dirty door sensor - plunger gets dirty - spray liberally with contact cleaner
Old Sep 15, 2024 | 09:03 PM
drivendesign's Avatar
If your 100% all of your door sensors and bulbs are working I'd look at the MFU. Swapped mine and fixed similar issues.
RH5555
Apr 17, 2024 10:34 AM
ep3w
May 14, 2020 09:00 PM
ahab
Mar 10, 2020 07:47 AM
mikebaus
Aug 15, 2015 09:58 PM
LADEROUTE
Jan 9, 2013 08:01 PM
