doors not opening
Old Feb 10, 2012 | 03:12 PM
wynhd's Avatar
Default doors not opening
I am sure this has been talked about prior but, I am unable to open my doors in my Disco 1, front doors only from the inside. This morning I got the nice suprise of the key freely spinning in the door lock. Is this something I can fix or does anyone know of a good mechanic in the Santa Clarita/ San Fernando Valley (Ca.) that is reasonable to fix this problem. The door issue had been there prior and I had someone "fix," but, looks like this was just a temporary adjustment. Any help or pointers will be greatly appreciated. I am looking to fix the issue permanently. Thanks,
Old Feb 10, 2012 | 04:14 PM
Ed Z's Avatar
Open up the door panel and have a look... Likely it's just some clips that have come apart or possibly broken...
Old Feb 11, 2012 | 02:30 PM
hh65flyer's Avatar
There are a variety of plastic parts that can and will break in conjunction with the door key. Likely that is what has happened. I was able to get one from a guy parting one out. I was lucky because most people wouldn't seperate that piece from te entire door mech (which I did not need). They are also door specific so you will need the part from a driver's side door.
Re the doors opening there is an adjustment that can be made to the rods once you remove the door cards. It's really not that difficult. I had the same problem and was able to adjust all mine back to working condition. Good luck!
wynhd
Aug 28, 2012 11:33 PM
gargar
Apr 19, 2011 09:28 PM
dieselgeek
Oct 6, 2009 01:49 PM
johnkbl
Apr 16, 2007 02:39 PM
abutoma
Mar 10, 2007 09:36 PM
