drive shaft splines coated with plastic?
Old 09-23-2010, 08:12 PM
NiteTrain's Avatar
Default drive shaft splines coated with plastic?
the splines on my rear driveshaft yoke are coated with plastic. I had to beat the yoke off with a 5 lbs sledge hammer and its not going back on easy with that plastic coating. I guess it's there to protect the metal but its making it really hard to install drive shaft since I can't compress or extend shaft.
I'm thinking about removing the plastic..has anybody did this?
Old 09-23-2010, 08:16 PM
Done this, has anybody done this?
Sorry, just had to be a *****.
No I have not done this.
Old 09-23-2010, 08:24 PM
NiteTrain's Avatar
hey I'm covered with grease and I have been beating on this drive shaft for the past hour so give me a break on the grammatical errors
anyways, its called a glide coat and it's non-replaceable..you have to buy a new yoke...how dumb is that?
Old 09-23-2010, 08:26 PM
That is pretty stupid.
I learned something about these trucks to day.
Old 09-23-2010, 08:31 PM
NiteTrain's Avatar
from what I've read so far it's made out of teflon and it's there to keep the shaft quiet and take out any play...if you remove it theres a chance the yokes days will be numbered and the shaft will make more noise
Old 09-23-2010, 08:43 PM
That makes sense, its amazing it has lasted this long.
Old 09-24-2010, 02:03 PM
NiteTrain's Avatar
well it was starting to peel in places and after beating it back into shaft it peeled even more...i had to remove it all...torch and wire brush. I guess we'll see how long my yoke last without it.
Old 09-24-2010, 02:16 PM
antichrist's Avatar
I would think without it you'll have significant radial play in the propshaft between the slip yoke and tube.
Old 09-24-2010, 02:42 PM
NiteTrain's Avatar
it fits fairly tight now but I can see how over time It might loosen up. This rover will not driven daily, so maybe it will be a long time before I need a new yoke. I had no other option, once that glide coat starts to peel re-installing the yoke into shaft just makes it peel more.
also, I don't like drive line components I have to beat with a sledge hammer in a vise. I prefer a little bit of play so I can get it apart on the trail if need be.
Old 09-24-2010, 05:26 PM
True, beating anything off with a five pound sledge is rarely ever fun.
Quick Reply: drive shaft splines coated with plastic?
