Driver side mirror glass mounting adapter Help
Old Feb 8, 2013 | 12:53 PM
plasticjesus's Avatar
7th Gear
Default Driver side mirror glass mounting adapter Help
I have purchased this part from Atlantic British
Mirror Glass Mounting Adaptor (Part # STC4625) - Land Rover body panels/fittings/trim exterior from Atlantic British
The old one has the tabs that hold the mirror glass broken so this will fix it. But I have not figured out how to remove and replace this part. Has anyone done this and is there a trick to this? I am afraid of breaking other parts getting the old one out. Any tips would be appreciated.
PS this is a 1998 discovery 1
Old Feb 8, 2013 | 09:29 PM
XCELLER8's Avatar
if memory serves me well....the adapter just pushes in or snaps into place and the glass snaps onto the adapter.....the adapter usually breaks when you remove it so its a good thing you have one coming....let us know for sure how this works
Old Feb 9, 2013 | 01:37 PM
Take it to a automotive glass shop, give them the parts, 10min and $20 later and you will be back on the road.
Old Feb 10, 2013 | 04:07 PM
7th Gear
So I changed it. It was as easy as pulling the old one and snapping the new one in. Thanks XCELLE8
Old Feb 10, 2013 | 09:23 PM
XCELLER8's Avatar
glad you got it fixed ....now on to ...?
Old Feb 11, 2013 | 09:24 AM
7th Gear
Oil pan gasket, Valve cover gaskets, Intake gaskets. Find a sunshade assembly for the sunroof and a passenger rear mudflap and a good set of power seats my leather is pretty worn.
ngarover
May 12, 2021 09:00 AM
SuperiorCarCare
Detailing
Feb 5, 2014 02:00 PM
acgroff
Dec 13, 2012 01:50 PM
BlueDisco
Feb 19, 2007 02:50 AM
