Driver side wheel noise
Old Apr 12, 2014 | 10:04 AM
tentoesjoe's Avatar
Default Driver side wheel noise
Hi this morning I got in my truck and started driving and it is making a loud rubbing noise. Its worse in reverse than in drive. Two weeks ago I replaced the bearings, rotors and pads so I pulled everything apart to see if anything was wrong and everything looked fine. Any ideas? It sounds like something is catching.
Old Apr 12, 2014 | 11:16 AM
CUpgt's Avatar
Caliper sticking?
Old Apr 12, 2014 | 11:51 AM
tentoesjoe's Avatar
Funny you should say that. I just pulled the tire off again and the bottom bolt on the caliper is seeping brake fluid. Any ideas on how to fix or just replace. Its my fault because I wanted to save a few and bought centric calipers.
Old Apr 12, 2014 | 02:19 PM
tentoesjoe's Avatar
update!!!! I pulled the caliper and its still making noise. Anybody? Oh and it only makes noise when I am driving. I can spin the wheel all day freehand and no noise.
Old Apr 12, 2014 | 06:46 PM
TOM R's Avatar
Cv bad?
Old Apr 12, 2014 | 07:19 PM
tentoesjoe's Avatar
Im not sure. I pulled it out and cleaned it up but i am not sure what it should look like.
Old Apr 12, 2014 | 08:47 PM
fishEH's Avatar
Did you follow the RAVE procedure(proper torque and whatnot) for the wheel bearings?
Old Apr 13, 2014 | 07:23 AM
tentoesjoe's Avatar
Yeah. But I pulled them back off and reseated them with no luck.
andrewsloop
May 23, 2014 08:08 PM
post42
Sep 10, 2013 03:33 PM
Princess
Sep 15, 2009 08:02 PM
buckyjoe1979
Apr 15, 2009 04:46 PM
BlueDisco
Feb 19, 2007 02:50 AM
