Rubbing on Driver's Side - Not wheel bearing or differential
Old May 23, 2014 | 03:54 PM
andrewsloop's Avatar
Default Rubbing on Driver's Side - Not wheel bearing or differential
2003 Disco II - 155,000 miles.
I am getting a constant rubbing / grinding noise with vibrations at 20 mph and up that I cannot identify. I have checked the hub and there is no play in the bearing. I just changed out the differential fluids and notices no metal shards. The noise increases with speed and is constant during braking. I can feel vibrations through the floorboard while the noise is being produced.
The vibrations and noise disappear completely when turning left. I cannot see any evidence of tires rubbing anywhere.
Any ideas what this could be?
Old May 23, 2014 | 04:40 PM
dusty1's Avatar
sticking caliper? bent shield rubbing? cv
Old May 23, 2014 | 05:27 PM
ralphobell's Avatar
Check your ABS sensor in the HUB. Happened to me. See this post:
https://landroverforums.com/forum/di...-w-pics-59222/
Old May 23, 2014 | 08:08 PM
Thanks gents. The pistons in the caliper are pretty rusty. It may be a sticking caliper. The sensor looks good. I'll check more thoroughly tomorrow and let you know what I find.
MPDano
Jun 15, 2015 09:24 AM
post42
Sep 10, 2013 03:33 PM
Disco28
Feb 27, 2013 10:49 PM
cbloomers
Aug 28, 2010 09:38 AM
