drivers door latch
Old Mar 31, 2014 | 01:51 PM
TOM R's Avatar
Default drivers door latch
OK drivers door has gotten annoying as hell, opens fine inside, outside latch seems to pick when it wants to work, suggestions before I tear the door apart as what to look for? Maybe something bent? Don't want to tear it apart if it is a known issue that will require parts
Old Mar 31, 2014 | 02:05 PM
OverRover's Avatar
Providing nothing is broken in the latch( that little F'ing spring), then you need to remove the door skin and adjust(shorten) the connecting rod between the handle and the latch. That rod can get very rusty so hit it with some oil/ PB Blaster first.
Old Mar 31, 2014 | 02:06 PM
jastutte's Avatar
i had the same issue with my 96 a few years back. pull the door panel and lube up all the moving parts. if i recall correctly, i messed with the adjustment but that didn't really help. seems the moving parts just needed to be lubricated.
Old Mar 31, 2014 | 02:07 PM
TOM R's Avatar
I know the little spring, lock is fine outside latch is nfg thanks
Old Mar 31, 2014 | 05:51 PM
TOM R's Avatar
Disconnected rod from latch to handle and adjusted a few turns till it connected correctly, the rod was adjusted out so it was pushing up on the cam piece attached to the handle quite a bit
Tried it a bunch of times and never worked this good before, sprayed the latch for good measure but it was greasy
Thanks for the suggestions
Old Apr 7, 2014 | 10:13 AM
jbunner's Avatar
Picture would be nice. My passenger door won't open from the outside and I paid $40 to get it looked at and they said it needed a $4 part and they didn't have it in stock so if I would bring it back they would fix it for $100.
Old Apr 8, 2014 | 08:50 PM
dipdgarage's Avatar
Pic would be awesome! I got one of my doors to work properly! Now, I still need to fix my other door. Can open from the inside and not from the outside! HELP lol
Old Apr 9, 2014 | 06:31 AM
TOM R's Avatar
Sorry it is close quarters and I took no pics, with the panel off it is self explanatory if you are mechanicaly inclined
ljdiscovery
Feb 10, 2014 08:58 PM
ToddD
Jun 24, 2012 09:14 AM
KGN96discoSE7
Apr 4, 2010 09:05 AM
CandiMan
Aug 24, 2008 10:35 PM
