Dumb cat???
Old Aug 1, 2010 | 04:42 PM
Cosmic88's Avatar
question on the magnaflow's... was the thread for the O2's correct or did the installer have to do any work there?
Old Aug 2, 2010 | 04:23 PM
okdiscoguy's Avatar
just cut the old cats out and fit the new one's in. Re-use the same bungs in the pipes.
Old Aug 2, 2010 | 05:27 PM
Cosmic88's Avatar
Default ah ha
so if I get you right you just cut the pipe after the o2's and wleded new cats in place...
Old Aug 2, 2010 | 06:03 PM
Long Haul's Avatar
Yes... your just cutting out just the old cat just behind the front 02 sensors and just in front of your rear 02 sensors
just read your sig..... you have a 95 with only front 02's so yes just cuttin the pipe behind them and fitting new cats will work
Last edited by Long Haul; Aug 2, 2010 at 06:05 PM. Reason: just saw you have 95 D1
Old Aug 2, 2010 | 06:14 PM
okdiscoguy's Avatar
I cut just before and after the cats and had the new one's welded in. The guy didn't do it to my liking, so I cut them out and re-welded them.
I will say that even though putting them up and taking them down is a pain, tacking them and then pulling the Y to fully weld is the way to go...
elboy0712
Dec 19, 2010 02:48 PM
armlock
Dec 29, 2007 07:20 PM
Nux
Oct 26, 2005 03:43 AM
brianwi11iams
Jul 30, 2005 09:06 PM
FORDSTANGER
Jun 7, 2005 06:02 PM
