No such thing as a dumb Disco just Dumb Owner
Old Oct 20, 2007 | 09:26 PM
armlock's Avatar
Default No such thing as a dumb Disco just Dumb Owner
Just purchased a 2002 Disco all doors were locking when i bought it then the 2 back doors quit locking 1 day later the drivers side quit now the only 2 that work are the passenger front and the rear, any suggestions. Thanks TN (Go Vols)
Old Oct 21, 2007 | 10:28 AM
Default RE: No such thing as a dumb Disco just Dumb Owner
I don't even know where to go with this question.
Old Oct 21, 2007 | 07:53 PM
okdiscoguy's Avatar
Not positive on D2's but I think you have a window lift ECU behind the glove box. Might be some broken solder joints on the circuit board. I know D1's have had the problem...There is a link out there describing it. Can't remember where....I'll see if I can find it again.
Old Oct 22, 2007 | 09:26 AM
armlock's Avatar
Thanks, I havent dug into it yet im trying to avoid taking the door panel off to check for voltage.
Old Oct 22, 2007 | 10:34 AM
okdiscoguy's Avatar
oops, I didn't read very well. The window lift ecu wouldn't have anything to do with it at all....( I think I fit into your title...) You are headed in the right direction. Check the actuators...
Old Oct 22, 2007 | 12:34 PM
armlock's Avatar
Thanks anyways, do you know of any magic tricks to remove the door panel?
Old Oct 22, 2007 | 12:36 PM
okdiscoguy's Avatar
Mine's different, maybe someone will chime in with a D2. I would get some extra clips for when you break them...
Old Dec 29, 2007 | 03:38 PM
pebbles's Avatar
armlock,
Did you ever figure out the problem with this? I am having similiar problems.
I can't get any of my doors to unlock with remote or internal dash switch. I can only use drivers door which must be manually unlocked with the key. All other doors are locked.
thanks
Old Dec 29, 2007 | 06:22 PM
Have you tried my suggest of changeing fuses yet?
Old Dec 29, 2007 | 07:20 PM
JayhawkinIdaho's Avatar
Stupid question, do they work with the button on the dash? I'm just asking because the signal from the key fob sometimes doesn'tlock all of my doors all of the time (low battery key fob), but when insidehitting the button on the dash it wakes them up especially when it is cold outside.
Chrisinhouston
Dec 23, 2018 01:35 PM
RoverBird75
Jul 23, 2012 03:02 PM
sleepercoupe
Apr 4, 2011 01:03 AM
thehun
Dec 7, 2010 12:03 PM
KBW
Feb 15, 2010 12:55 PM
