Dumbass new guy question
Old Feb 22, 2019 | 08:52 PM
dialtonehero57's Avatar
Default Dumbass new guy question
How does one tell what year LR they have? I can’t find stickers anywhere on mine. I mainly concerned so I can get the correct part numbers. Also are there Land Rover part houses like Victoria British for MG and Triumph ?
Old Feb 22, 2019 | 09:01 PM
Welcome to the forum.
Still have a MG?
For new parts I generally hit up Lucky8. Used parts I hit up Paul Grant, Will Tillery and Abran for the newer stuff.
Running the vin should tell you the year. If it has a distributor under the hood it’s a 94/95. No distributor than its 96-99
Old Feb 22, 2019 | 09:53 PM
Still have a MG?
lol had a MG in college what a money pit! I have EFI so I’ll start with plugs and wires then maybe coil packs.
Old Feb 23, 2019 | 08:11 AM
jimvw57's Avatar
first glance I would guess a D1, the D2 has the tail lights higher up. Take a good look at the swivel ***** on the front axle. they tend to leak oil and when they run dry, you mess up the pivot bearings.
Old Feb 23, 2019 | 08:34 AM
robertf's Avatar
The antenna placement,door trim width, and tail lamps are the only external clues to the year Im aware of.
Inside you can tell by looking at seats mounts, rear arm rest, drivers visor, headliner trim and a pillar trim.
thats a 97 or later.
you could also look at the epa compliance year tag under the hood
Old Feb 23, 2019 | 09:07 AM
Both distributor and coil pack we're EFI
Old Feb 23, 2019 | 10:55 AM
thanks for that tip
Old Feb 25, 2019 | 07:31 AM
WaltNYC's Avatar
VIN decoder.... no guessing involved.
https://landroverforums.com/forum/vindecoder.php
good suppliers of new parts include...
roverparts.com - British Atlantic - Eric Riston has been super helpful
roversnorth.com - Rovers North
https://rovahfarm.com/ - Rovah Farm - Trevor is great.
https://www.lucky8llc.com/ - Lucky 8
LRdirect.com - UK based part supplier. Sometimes cheaper than the U.S. houses.
Old Feb 25, 2019 | 09:40 AM
thank you. I’m starting with new plugs then I’ll start it and read the codes again.
Icculus38
Jun 18, 2023 12:54 PM
Fastercat
Build Threads
259
Mar 12, 2023 08:08 PM
ToiletDuck
Jan 11, 2019 03:07 PM
DakotaTravler
Mar 5, 2018 07:03 AM
ROB99DISCOSD
Jan 14, 2018 09:34 AM
